48 ford frame swap?
Discussion in 'The Hokey Ass Message Board' started by metalinker, Dec 14, 2009.
  1. metalinker
    metalinker
    Hello all. I would like to upgrade 1948 ford f68 3/4 ton. Any ideas on a suitable donor frame. I've put a 1953 gmc one ton on an s10 but I thought it was a little wide over the s 10 chasis.
    It still powered by the flatty and I would like to keep that in it. Suggestions? Thanks. WarD
  2. What's wrong with the frame under it? They're pretty basic from what I remember.
  3. Really depends what you want to use it for. I'm with Rusty. Why swap the frame??
  4. HotRod33
    HotRod33
    I drove a 1948 ford pickup for 18 years with a FATMAN'S mustang II CROSSMEMBER UNDER THE FRONT END.......... rode and handled great and it was not nearly as much work as a frame swap.....
  5. bobj49f2
    bobj49f2
    The one disadvantage 3/4 ton ch***is I can think of is the weight. It's a little heavier than the 1/2 ton. The easiest thing to do is find a F-1 frame and transfer your engine and sheet metal. You should be able to find a rotted F-1 fairly easy. The frames usually hold up longer than the bodies. You'd also have either lengthen the frame or shorten your box. You could also just swap axles on your original frame. There's easier ways than swapping onto a newer frame.
  6. PhilJohnson
    PhilJohnson
    Never heard of swamping axles, I prefer my axles dry :D
  7. bobj49f2
    bobj49f2
    There, I fixed it.
  8. AnimalAin
    AnimalAin
    I think one of the key questions has to be what are you going to do with it? If it is going to be a beast of burden, or tow big, heavy stuff, you need one thing; if you want to get to/from work and drag a Christmas tree home every year, lighter-duty stuff will do.
