Art & Inspiration 48 Ford hub dimensions
Discussion in 'The Hokey Ass Message Board' started by 55willys, Dec 25, 2017.
  1. 55willys
    55willys
    I am working on a new hub design and am in need of some dimensions for a 46-48 Ford hub. What I need are outer bearing seat to outer end of hub. Outer end of hub to wheel mounting surface. Thickness of wheel mounting surface to drum mounting surface. I have a 40 Ford hub but my 48 hubs were stolen. Thanks.
  2. 55willys
    55willys
    I know it is Christmas but not even one response?
  3. 55willys
    55willys
    I am still looking for this information
  4. Tetanus
    Tetanus
    I think I have a set or 2 of hubs I can check in a few days. not sure what u mean by " Thickness of wheel mounting surface to drum mounting surface" also outer hub to bearing seat u mean the step where the bearing outer race bottoms out on? pm me if you don't hear back in a while to remind me.some had drums mount on outside and some inside not sure what I got and if there is difference?????????
  5. 55willys
    55willys
    Thanks Tetanus,
    The hub that I need dimensions of has the brake drum mounted on the back side.
  6. Tetanus
    Tetanus
    ok checked it out. from end of hub to where bearing race seats is 1.059. from end of hub to wheel mounting surface checks 1.738. thickness of wheel mounting flange is .353. All checked with micrometers. this was on a 46 where drum is mounted to back of wheel mounting flange.
    bct likes this.
  7. 55willys
    55willys
    Thank you very much Tetanus, those are all the dimensions that I needed.
