49-52 chev front clip
Discussion in 'The Hokey Ass Message Board' started by oldcarnut47, Mar 10, 2009.
  1. oldcarnut47
    oldcarnut47
    can someone tell me if the front sheet metal and dash from a 52 chev fleetline 4 door will fit on a 49 fleetline2 door , i am talking too a guy that has both , the 52 would makle a good donar car and i prefer the front end and dash of the 52 if it will fit on the 49.
    i did a search and found a lot of posts saying a lot of the parts interchange but nothing about these particular parts
  2. 53sled
    53sled
    from KCMO
    damn near everything will swap 49-54, except deck lids and glass. other parts you should grab- front brakes, the 52 trans crossmember is a bolt in instead of riveted like the 49-51, i think, so it is easier for future work, might as well grab both if they are cheap, and you have room.
  3. I have actually done this swap...a buddy and I found a junkyard with several cars, and swapped front suspension, sheetmetal, bumpers, from a '52 sedan onto a '49 coupe...
    The dashboard we didn't touch...
  4. atomickustom
    atomickustom
    Everything will interchange. The dash is welded in, though, not a bolt-on item.
  5. oldcarnut47
    oldcarnut47
    thank you guys, i figured somebody on here would know, im going to try to buy both cars if the guys not stroking me, will post the results.
