49-52 versus 53-54 Chevy uprights
Discussion in 'The Hokey Ass Message Board' started by slammed49, Oct 1, 2006.
  1. slammed49
    slammed49
    I think I read on here somewhere that the later uprights could be used to lower the early cars about 1"....ring a bell to anyone? Thanks
  2. Kustm52
    Kustm52
    Yep. Direct swap, but a lot of work for 3/4" to 1".
    Brian
  3. ray
    ray
    from colorado
    maybe, but every inch matters. i've done much more drastic things to get an inch.
  4. lucforce
    lucforce
    Are the steering arm placements the same?
  5. OLLIN
    OLLIN
    yuck! hahahahahaha.
  6. i didnt know that that later spindles could be swapped for the earlier ones. and you say it lowers it 3/4-1 inch? would you be able to get 2.75-3 inches if you used the dropped spindles for the 53-54 on the 49-52? thats a spindle swap that might be worth it! (i dont know if the 53-54 has dropped spindles either)
  7. You don't put lowered spindles on them, it's the uprights that you change. There's no such thing as a dropped spindle for a '49-'54 Chevy.
  8. ok now i really feel like a dumb***. i just ***umed that when everyone was talking about "uprights", that they were talking about the spindles... ill shut up now, haha
  9. Gasserfreak
    Gasserfreak
    from Yuma, AZ
    Well, not to dredge up an old post, but I was doing a search and found this post and was wondering the same thing. Has anyone ever put dropped 53-54 uprights on a 49-52? Was the result even more drop that just dropped 49-52 uprights? And yes aal the catalogs I've looked at show dropped 53-54 uprights, and show 2-2.5 inches of drop also. Thanks
    Drew
  10. slammed49
    slammed49
    The aftermarket or dropped uprights all lower the car the same amount...the OEM uprights on a 53-54 are 1 inch lower the the earlier ones,after Buffalo modifies them they are all the same,Fatmans are fabbed are the are all the same also,go with Buffs,$250 exchange and you DO NOT need modified steering arms
  11. choptop30
    choptop30
    from Arkansas
    I know this is an older thread but dose anyone know the casting numbers for the 53 54 spindle uprights?
    thanks
    Don
  12. MAD MIKE
    MAD MIKE
    from 94577
  13. choptop30
    choptop30
    from Arkansas
  14. Rusty O'Toole
    Rusty O'Toole
