Hot Rods 49-54 Chevy car hub interchange.
Discussion in 'The Hokey Ass Message Board' started by autowa, Jun 6, 2025.
  1. autowa
    autowa
    from mendota,il
    Would 49-54 Pontiac front hub or something else with a 5x5 bolt pattern fit a 49-54 Chevy car spindle? I have some old mags I would like to use on my T-Bucket I'm building, thanks.
  2. 1biggun
    1biggun
    If you were willing to go to disk brakes there is a GM car hub that I know is used on conversion kits that I think Speedway also sells in a 5 on 5" for the stock car applications.
  3. 325w
    325w
    Google says inner bearing the same. Many years use same outer. Might work
  4. fastcar1953
    fastcar1953
    53 and 54 are the same . 49 to 52 used different brakes . none were 5x5
    1971BB427 likes this.
  5. FRANK GRELLE
    FRANK GRELLE
    53 ,54 Chevy is 5" x 4"3/4 lug.
  6. RICH B
    RICH B
    Parts listing shows same inner & outer wheel bearings along with the seal; but if I remember right Pontiacs had bigger brakes so could be an issue.
    Probably be better off drilling your Chev hubs and drums to 5 on 5.
    brading likes this.
  7. 1971BB427
    1971BB427
    from Oregon
    I think you meant 5 lug x 4.75" pattern?
