49-54 Chevy Frame Question
Discussion in 'Off Topic Hot Rods & Customs' started by SDrocker, Feb 25, 2026.
  1. SDrocker
    SDrocker
    the ***le vin matches the vin plate on the a pillar albeit the ***le is a New Mexico ***le.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    overlapped sheet metal in the sail panel area (near the rear window) is certainly not a sign of a quality job. pin hole rust, rough bodywork... I would say sell and learn a lesson on looking at cars before you buy them and don't let sellers strong arm you into giving a deposit before you have seen it
    49ratfink likes this.
  3. SDrocker
    SDrocker
    Thanks.. I don’t think any body work has been done just the metal work.. the seller mentioned to me to do body work to it one panel at a time so he implied just the metal work was done.
    The overlapping sail panel seems to indicate bad work though as you said.
    I’ll get this back on the ground and try to unload it at a loss….
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    I can guarantee you there has been bodywork (bondo) done on it... good for you for unloading it and learning a lesson. this would have been a bottomless pit of problems
  5. SDrocker
    SDrocker
    Is the easy to find where there is heavy bondo using a small magnet? I can feel a small magnet sticking in all the areas where the panels and chop work was done thus far. Is the trick to feel where the magnet doesn’t stick as strong? There isn’t anywhere that the magnet is sticking thus far when checking.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    if it isn't very thick a magnet will stick, just not as well as if there isn't any plastic filler. a thin flexible refrigerator magnet is handy for checking for bondo as they are not very strong
    SS327 and TrailerTrashToo like this.
  7. 49ratfink
    49ratfink
  8. SDrocker
    SDrocker
    with a weaker magnet I can feel where there is a little bondo but it’s definitely not where the sail panel overlaps on the inside.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    that is just poor workmanship. it looks like the gasket has a gap all along the bottom edge. I bet you would be horrified if you took the window out (please don't)
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    also whoever put the side gl*** in it did not know what they were doing. It appears like yhe quarter gl*** is glued in and is not weather stripped or sealed to the outer body? it may whistle going down the road and will probably leak water in the rain? was anything done correctly on this poor car?
  11. SDrocker
    SDrocker
    that’s what I see… this is similar to what I saw on my chopped 50 ford shoebox only it had the chrome trim with felt between the gl*** and outer body… that one was not meant to be left outdoors..
    I imagine the same thing was intended for this one as well.
    the two other chopped cars I had were fair weather cars and could not be driven in the rain..
  12. SS327
    SS327
    At least the welds that are showing are quality welds. The gaps can be filled with steel rod or opened up with a grinder. You seem reluctant to learn to weld. If so then maybe selling is the correct choice? But! I don’t think you need to loose money on it. I can see it in that condition being worth the money. A guy in his garage could fix the issues reasonably easy in a reasonable amount of time. In less time than a home chop would take.
  13. SS327
    SS327
    Steel and welding. :D Seriously though you won’t know until you get the gl*** out and the paint off. Some metal, a mig welder and a shrinker stretcher maybe a small cheap sheet metal brake. Some hammers and dollies should be all you need. Except for the welder Harbor Freight tools should be more than adequate.
  14. Ok that's a strong point FOR the car. Trust me
    TrailerTrashToo and SS327 like this.
  15. simplestone
    simplestone
    I would be very concerned with the pin holes of rust near the bottom of the body. Those may indicate a large amount of very thin metal to work with when trying to fix. That would most likely entail cutting and large patch panels. I could be wrong, but it could be a can of worms...
    Moriarity likes this.
  16. 49ratfink
    49ratfink
    here's a simple way to check for excess paint/filler on your car. you can get the same exact one for less on Amazon, but this seller shows a good photo of how it works.this one says it is for paint thickness, so it may not even stick on some areas at all on this car
    https://www.amazon.com/dp/B0CJY96CP4/?tag=atomicindus08-20
  17. Turn the cap to the first notch.
  18. gene-koning
    gene-koning
    These two statements pretty much cover this car.
    I think you probably need to learn when to walk away, before you hand over your money.
    The two guys were scam artists and told you what ever they thought you wanted to hear.
    I suspect this is going to be an expensive lesson before its all done. The good news about that is you probably won't make those mistakes again very soon.
    TrailerTrashToo and Moriarity like this.
  19. SDrocker
    SDrocker
    it doesn’t seem to want to turn any more.
    also don’t I need an overflow tank regardless?
  20. I mean loosen it to first notch
  21. gene-koning
    gene-koning
    If you don't have the conversations, recorded, its going to be their word against your word, and there are two of them.
    Then you will have to be able to prove they knew the things that were done were unsafe.
    It would be your choice to pursue legal or small claims to get your money back, but even if you win, you would still have to be able to collect it.
    I took a guy to small claims court and won, the judge told me I could collect my money using any legal process available. Never got a penny of it. I wish you luck if you go in that direction.
  22. 6sally6
    6sally6
    For trips in & out of the garage....you don't need to top-off the radiator. 3/4 full and it 'shouldn't ' spew & steam...
    6sally6
    PS Your in wayyyy over your head.
    Eastwood said it best..."A man's got to know his limitations"
  23. Just sent you a message on fb
