49-54 chevy header alternative?
Discussion in 'The Hokey Ass Message Board' started by 40hemicpe, Jan 18, 2010.
  1. 40hemicpe
    40hemicpe
    from anaheim.ca
    i keep hearing of headers from trucks and camaros and other type of gm cars.that these will fit in 49-54 chevy v/8 swap anybody have part numbers and or what years fit and pics installed i know this would help alot of us out there.i know that sanderson makes headers that will work but seen the truck headers and others go much less.im also talking use with stock suspension i know block huggers wont work and rams horn wont.i already know about log manifolds and such.so anybody out there got any info.thanks:)
  2. DECKARD sr.
    DECKARD sr.
    from what i've heard caprice manifolds will work. i hope so, cause i just blasted and painted mine last night. it looks like their gonna work just fine. i'll post pics later...
  3. 40hemicpe
    40hemicpe
    from anaheim.ca
    i know caprice manifolds work i have them on my 49.but need to know what headers will work for 49-54?
  4. 53sled
    53sled
    from KCMO
    MAYBE s10 v8 conversion headers, but I don't know for sure. Fenderwell 55-57 headers may be a better idea.
  5. 49ratfink
    49ratfink
    because of the wacky steering on these there is no way a full header where the collectors are under the car will work. there might be some sort of rear dump "shorty" header that would work, but then you get into problems with the underfloor brake pedal hitting the header when the pedal is pushed.
    if you changed over to a firewall mount master cylinder this would cure that problem.
    fenderwell headers are another option.
    I had Sandersons on my old 49 sedan. it's a tight fit around the oil filter, and you'll need an exhaust guy who strives to do a quality job if you want to keep it all tucked above the frame. not every exhaust guy could or would do it right.
  6. John Denich
    John Denich
    I use Hedman 68600 Camaro header, I used with the stock suspension and now with the MustangII no issues and fits like a glove!
  7. russnunn
    russnunn
    from Florida
    good info i will be looking myself for headers soon
  8. 40hemicpe
    40hemicpe
    from anaheim.ca
    thanks for the info on those headers also heard 58 impala?
  9. CARLOS8A
    CARLOS8A
    from waukegan
    I have caprice manifolds on mine and it clears the sterring arm!! I bought a set of hugger headers and they wont work bc the steering gear on my 52 gets in the way!!
  10. 40hemicpe
    40hemicpe
    from anaheim.ca
    block huggers only work with mII setups.i know 80"s-90"s truck. camaro. caprice.manifolds work.also early nova.
  11. CARLOS8A
    CARLOS8A
    from waukegan
    actually my buddy also has a 52 and he has block huggers and has the stock suspension , so hugger headers will work with stock suspension depending on your motor mounts.
  12. 40hemicpe
    40hemicpe
    from anaheim.ca
    the motor sit alot back or far forward? ive done alot of these v/8 swaps and usually use sanderson headers but like i said there has to be alternatives
  13. aldixie
    aldixie
    I'm using Mid 80's Chevy pickup manifolds. I couldn't use block huggers as they got in the way of my crossmember.
  14. 40hemicpe
    40hemicpe
    from anaheim.ca
    yeah the only way maybe if the motor was pushed back alot or really far forward huggers might work but to me wouldnt look good.
  15. Your mid-80s truck manifolds, does the left dump between the middle and rear ports and aim more or less straight down, or do they both dump at the rear at roughly a 45' angle? After a ton of research as close as I can tell there's two basic types but there's no real rhyme or reason what truck you'll find them on.
  16. 40hemicpe
    40hemicpe
    from anaheim.ca
    drivers side is between the last 2 cylinders and exit staright down the p***enger side angles at a 45 exits at the rear of the last cylinder
  17. Greezeball
    Greezeball
    Trust John on that part #. Before he ended up in so.cal. he worked for a performance parts shop and was the mix n match master.
  18. CARLOS8A
    CARLOS8A
    from waukegan
    here is my buddys 1952 chevy deluxe with a 283 and a th350 trans hugger headers, stock suspension!!!!
    cody ellingson likes this.
  19. 40hemicpe
    40hemicpe
    from anaheim.ca
    well i"ll be damned:eek:.do you got part#s for those
  20. CARLOS8A
    CARLOS8A
    from waukegan
    negative no part numbers......... they are just sbc hugger headers!!!
  21. 40hemicpe
    40hemicpe
    from anaheim.ca
    i see they tuck in tighter then most block huggers
  22. J.Royseth
    J.Royseth
    from Norway
    On my -53 I used Hedman headers. They make (or made) a model with a flat collector. Don't remember the part #,but I guess you'll find them somewhere.
    I also tried block-huggers,but they had no chance on the steering-side.
    Do a search on Hedman.-I really recommend them.
  23. CARLOS8A
    CARLOS8A
    from waukegan
    yeah they are in there pritty tight but everything works just fine!!! like i said depending on your motor mounts you can run huggers no problem.... hopefully the pics i posted can help a fellow hamb member!!!
  24. holeshot
    holeshot
    from Waxahachie
    HEMI...didn't you see DECKERD'S avator. i do believe it's a 49-50 chevy. but either way man JEG'S mail order can fix you up...POP.
  25. 40hemicpe
    40hemicpe
    from anaheim.ca
    yeah i saw his avatar.. i already know about the caprice /truck manifolds for the thousandth time.asking about headers..
  26. Von Rigg Fink
    Von Rigg Fink
    from Garage
    make um
    or sandersons
    zzford likes this.
  27. aldixie
    aldixie
    I couldn't use the huggers as I have Jaguar IFS which is rear stear and they came into contact at the ujoint connection to the power rack. The drivers side on the truck manifold is a rear dump at 45 degrees and the p***enger is center dump at 45 degrees.
  28. Pontius
    Pontius
  29. Skinned Knuckles
    Skinned Knuckles
  30. Skinned Knuckles
    Skinned Knuckles
    This was very useful info. I have Flowtech long tubes on a 50 coupe with Mustang II front suspension. Car is low and they drag. Not fun. I tried the 68600’s. The clutch bell crank fit perfect between 2nd and 3rd tube just like my long tubes but the collector totally blocked the clutch throw out arm.
    Ordered the 68640’s. It looks like they will work perfect.
    I don’t like that they look very different left from right but it’s necessary to clear the clutch linkage.
    With auto transmission the 68600 are definitely the way to go.
