49 Ass draggers
Discussion in 'The Hokey Ass Message Board' started by FRANKENSTEIN1313, Oct 5, 2012.
  1. FRANKENSTEIN1313
    FRANKENSTEIN1313
    I lowerd my 49 F1 in the back about 12 inches and left the front stock. I tried to line everything up and it drives ok and looks good and have taken it to a couple shows but keep breaking u-joints? Suggestions
  2. 49ratfink
    49ratfink
    bring extra U-joints everywhere you go.
  3. Carter
    Carter
    Suggestions?
    Either lower the front at least 10 inches or raise the rear at least 10 inches.
    Oh you meant suggestions on your driveline issues?
    How is your pinion angle?
    Sent from my DROID device using the TJJ mobile app
  4. People gotta be makin this **** up.
  5. FRANKENSTEIN1313
    FRANKENSTEIN1313
    Looks ok. Doenst seem like it binds any where. First time lowering besides cutting the springs in my fifty and using lowering blocks.
  6. Carter
    Carter
    what method did you use to achieve this drop?
  7. FRANKENSTEIN1313
    FRANKENSTEIN1313
    Took out a couple springs, and put the springs under the axle.
  8. Carter
    Carter
    Need to know more about the truck. all stock? driveshaft too short, maybe?
  9. FRANKENSTEIN1313
    FRANKENSTEIN1313
    All stock.. Flat head v8. Never thought about the shaft being too short. I drove it about 60 miles to the last show and thought its was good to go and then on my way back it broke again.
  10. 1951Streamliner
    1951Streamliner
    from Reno, NV
    Posting pictures of the situation might help people see something you're missing. Also curious to see a truck that's 12 inches lower in the rear
  11. FRANKENSTEIN1313
    FRANKENSTEIN1313
    I'll take some pics this weekend and put them out there. There is a pic of the truck behind me in one of my pics but I'll get you a side veiw.
  12. cmyhtrod
    cmyhtrod
    from ct
    If the drive shaft is too short it will make a hell of a noise when it bottoms out on the tailshaft..
  13. FRANKENSTEIN1313
    FRANKENSTEIN1313
    No noise.... I was just reading about useing shives to hold everthing in place?
