49 Chevy 3600
Discussion in 'The Hokey Ass Message Board' started by rvick, Nov 23, 2011.
  1. rvick
    rvick
    I have been sniffing around alot on the internet trying to find info about doing a S-10 frame swap on my 49. I have noticed that the most recommended S-10 frame is the regular cab long box (117.9 wheelbase). My 49 is a 3600 and has a wheelbase of i think 125.75. I am pretty sure from what i have seen that the extended cab S-10 wheelbase is 122. this would be pretty close to what i think i need (someone correct me if i'm wrong). I haven't seen on here anyone talking about swaping with 3600 which is longer than 3100. Anyway, I am going to do full custom on this project but i have only just got the truck torn down. I am in West Point, MS and looking for an extended cab frame and suspension. Also, while i have this thread open let me ask if anyone can help with steering? I am planning on going with a 350 engine and was wandering what my options will be with steering and steering boxes? will the stock s-10 stuff work?
  2. pottsie454
    pottsie454
    If you didnt want to do a full frame you could always do a front clip... nova or camaro. Or just buy a mustang 2 front clip.
  3. rvick
    rvick
    I agree that the front clip option sounds appealing but when i factor in the cost of the mustang II and then with my skill level getting everything lined back up is out of my league. However if it weren't for the cost i would probably go that route because I have seen some really tough looking upgrades to the mustang II.
  4. 47 owner
    47 owner
    I have been looking for a s-10 donor as well. I am in California. Do you have a 1 ton or 3/4 ton truck?
  5. jetnow1
    jetnow1
    from CT
    The 3600 (3/4 ton) id the same cab/front sheet metal as the 3100 (!/2 ton) It even has
    the same front springs. The 1/2 ton axle/spindles bolt in in place of the 3/4 ton stuff
    giving you access to many options for brakes and front suspension lowering without
    welding. The rear axle is already an open rear end but is 8 bolt, huck brakes on a 49,
    and 4.57 gears so there are many reasons to swap to a later axle. Many people have
    shortened the bed to whatever size they need. If you feel the mustang two is beyond your skill level what makes you feel you can line up/fabricate etc a frame swap? There
    are bolt in mustang two kits made so if you feel welding is the issue that is another
    option.
    There are mobile welding services that can come to you and do the final welding if
    you have everything tacked in place for reasonable dollars. There are some well done
    s-10 swaps I like Flippers here on the AD group- but it has pro's and con's as well as
    anything else does.
    My truck is a 50 3/4 ton so I have been going thru much of the same research you
    have- for me the 1/2 ton axle swap makes the most sense. I like the longer bed but
    have seen shortened 3/4 tons fitted with the shorter 1/2 ton bed. Do what makes
    your truck right for you but evaluate carefully the s-10 swap. It is not as easy as
    many people seem to think.
    Check with the AD social group here- many very helpful people including some who have done this swap. They are less judgemental about the swap but can give you some
    real insight into what is truly involved and how much work it really is.
    Goon luck with your truck. Jim
  6. D-man313
    D-man313
    I just finished up my 49 with a s10 frame swap. If anybody wants more info, feel free to PM me.
  7. rusty1
    rusty1
    ...I'd shorten your truck to 1/2 ton wheelbase and build it that way.
    it'll look better, and have a much better resale value down the road. You can shorten your bed, runnin boards and splash aprons to fit....just my 2 cents.
    good luck with it , looks like a good project.
  8. rvick
    rvick
    I guess I was under the impression that by using the s10 frame that the geometry would already be set then all I would have to do is the body and engine mounts and line that up instead of the steering and such. I am comfortable with that, but if that still has to be changed then clip swap may be better, hell I don't know I am still in planning mode I guess LOL
