Technical 49 Chevy Fleetline Deluxe
Discussion in 'Traditional Customs' started by Martin Jarquin, Jan 22, 2025.
  1. Martin Jarquin
    Martin Jarquin
    Hey all,
    I have a 49 chevy fleetline, with a 216, where recently the timing gear went bad. So i just pulled motor and was wondering. Is it better to rebuild the original 216 or do a 235 swap? Will a 235 bolt right up to my 216 bellhousing and 3spd transmission?
    hrm2k likes this.
  2. A 235 would be a much better engine to build. Get one made after 1954 because they have full pressure lubrication and do not have the Babbitt bearings your 216 has. They made the 235 through the 1962 model year, and yes, they will bolt up to your 216 bellhousing. The only catch is the water pump, but I believe there is a conversion pump available.
  3. 50chevytx
    50chevytx
    You will need the front timing plate from the 216 as it has the motor mounts. It’s a job but better than trying to drill the 235 front plate.
  4. Martin Jarquin
    Martin Jarquin
    Are you able to read the chevy serial numbers?if so, i have a chevy 235 block that reads con4 , K101 , and 3764476
    Truckdoctor Andy likes this.
  5. F-ONE
    F-ONE
    from Alabama
    I would just replace the timing gear if it was a good runner.
    hrm2k likes this.
  6. 302GMC
    302GMC
    from Idaho
    How well did it run ? If it wasn't making any noises, I'd do the head, pull the pan & check the bearings for acid etch, ball de-glaze it, ring it & adjust rods & mains .0015 - .002
    Get the metal timing gear ...
    Buy a '49 - '54 shop manual.
    If you go 235, find a '54 core to build & get the "848'' head from a '57 - '62
    Maybe put your location in your avatar; might be someone close with parts ...
  7. I can’t, maybe @squirrel can. He’s our resident numbers expert.
    Martin Jarquin likes this.
  8. squirrel
    that sounds like a 1962 model 235 engine. What is the stamped numbers by the distributor?
  9. RATRODCHEVY
    RATRODCHEVY
    My Fleetline was a 216 with the 4.11 torque tube I upgraded to a 261 and 3.55 torque tube. Best decision I made. The 261 (or a 235) would give you much more power, and the lower rear axle is a big improvement in drivability. Might take some time to find a good 235 but it will make your car more reliable. Just my two cents….
  10. I hated 6s growing up. Now I save as many as I can from the s**** yard. Cool ones anyway.
    If the 216 is fixable, might be worth a shot. Even if it’s just to get ya by as you source a 235.
    My FB marketplace has several at decent $$$$
    Just got this one Saturday for $0. Guy posted it for free during a garage clean up
    saved a 261 out of a bus for $125 a couple years back.
    54delray, norms30a, Okie Pete and 3 others like this.
  11. Martin Jarquin
    Martin Jarquin
    371062CAL is stamped by the distributor. I have a set of 235 heads that read CON 13, G264 , & 3835913. Would these be compatible?
  12. Martin Jarquin
    Martin Jarquin
    It ran great, didnt leak oil just burnt a little. I would drive it 50 miles to San Francisco going to car shows and back from where i live.just under 60,000 original miles, i did drive it alot on the freeway cruising 60-65. Its a 12 volt conversion with petronix electronic ignition. Only trouble it ever gave me was blowing the original radiator, but that was a quick fix.
  13. Martin Jarquin
    Martin Jarquin
    Do you know where i can get the water pump conversion?
  14. I believe Chev’s of the 40’s has the conversion water pump.
  15. HEATHEN
    HEATHEN
    from SIDNEY, NY
    There are two choices on the water pump; either a modified '55-'62 style pump, or a plate that allows you to bolt the early style pump to the later style block.
  16. wheeltramp brian
    wheeltramp brian
    I would fix the timing gear and get it back on the road, so you can enjoy it and then fix up the 235.
  17. squirrel
    That doesn't look like a normal Chevy number. A picture of it might help?
    that should be a 1954 head...I think it fits the later 235 block.
  18. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yes, the heads interchange from 1953-62.
    squirrel likes this.
  19. 49ratfink
    49ratfink
    I'm a big fan of V8's in these cars. drove mine to Paso way back when. coming back I saw an AD truck, and a 51 and 53 p***enger car all old school doing 60 down the freeway so I p***ed them doing 80. :)
  20. I like getting p***ed by other cars
  21. For the record power glide 1953 235s were also full pressure hydraulic lifter engines
  22. lumpy 63
    lumpy 63
    When I was a kid in high School when we would swap in a 55-62 235 in place of a 216 we would press the water pump pulley flange down and use an early 60s falcon 6 cyl WP pulley . Usually had to trim a bit off the shaft afterwards with a die grinder.
  23. pprather
    pprather
  24. Martin Jarquin
    Martin Jarquin
    My 235 block is setup with hydraulic cam and lifters. Does 235 heads use the same rocker arm ***embly for hydraulic and solid lifters?
  25. I think 50-58 are the same. 59-62 has some difference
  26. HEATHEN
    HEATHEN
    from SIDNEY, NY
    All 235s had the same adjustable rocker arms. I think that the '59-'62 rocker ***embly had a difference in the oiling setup.
  27. BoxOfParts
    BoxOfParts
    I am in the process of doing just that , see if you can find a ***le "box of parts" in this section . I havent finished it yet but I have taken pictures and list problems I ran into, Many members have giving me advice.
  28. Martin Jarquin
    Martin Jarquin
    IMG_1928.png Thankyou all for your reply’s and suggestions. I just got my 235 running, but i am having a issue where oil is shooting out from one of the rockers causing less oil going to the others, it wont let me upload the video to this thread to show yall. But if you can, you can copy and paste the link below to the youtube short i just uploaded showing the oil shooting out from the rocker. Any suggestions on what to do will be very much appreciated.
    https://youtube.com/shorts/j68NicRSavQ?si=WdNlolwwTe2DBzJE
  29. BJR
    BJR
    Plug the hole, none of the other rockers have a hole there.
    patsurf likes this.
  30. 1-SHOT
    1-SHOT
    from Denton
    Anthony you need to transpose the last 2 numbers in that 216 they make a big difference
    anthony myrick likes this.
