Technical 49 chevy fleetline trunk hole for gas sending unit
Discussion in 'The Hokey Ass Message Board' started by 0nedon, Apr 14, 2024.
  1. 0nedon
    0nedon
    Before I empty the trunk and pull the mat I was hoping someone knows if there is a inspection hole pannel in the trunk floor itself. thaanks for the info
  2. Timmon
    Timmon
    can vary depending on factors like previous modifications or restoration work.
    most of them should have a hole like that
  3. 0nedon
    0nedon
    anybody with first hand knowledge the car is stock
  4. rusty1
    rusty1
    don't think they had an access panel...
  5. BJR
    BJR
    Just lift up the mat and be done with it.:eek:
    leon bee and Bob Lowry like this.
  6. If it’s the same as my 50 that’s a big NOPE !
    no hole for sending unit access , unless some previous owner was slightly smarter and slightly Hamb fisted and created one .
  7. 52HardTop
    52HardTop
    Nope, just make your own hole and make it easy for yourself. I did it with both of my cars. It's a lot less work than dropping the tank. I did it first in the Hard Top, when the new Auto Meter sending unit worked intermittently. I had to replace it with a replacement.
  8. 325w
    325w
    The tanks were so easy to drop. I’m guessing GM saved a bunch of Money not doing a hole
  9. 0nedon
    0nedon
    thanks for the info. guys guess I.ll drop the tank and cut one in while the tank is out of the way and I can see exactly where it should be to bad there is not a diagram to show where to cut the hole and not drop the tank
  10. rusty1
    rusty1
    I wouldn't want to make sparks cutting a hole above a gas tank that's still mounted!!!
    hrm2k likes this.
  11. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Dropping the tank out of my '53 wasn't a big deal; in fact, it has a 1/8 pipe plug in the bottom that allows you to drain it first.
    Hnstray likes this.
  12. jimmy six
    jimmy six
    While you’re at it replace the feed line to the carb with a bigger line. I believe the early 6’s had a 1/4”. A 5/16” will feed any V8 or built 6.
