Customs 49 ford Gambino notch kit completed... Pictures!
Discussion in 'The Hokey Ass Message Board' started by Ian Berky, Sep 3, 2009.
  1. dirt t
    dirt t
    1. HAMB Old Farts' Club
    You are one talanted dude.
  2. MUNCIE
    MUNCIE
    from Houston
    Nice thanks for posting the pics on the truck.
  3. Ian Berky
    Ian Berky
  4. Ian Berky
    Ian Berky
  5. moter
    moter
    Looking good Ian! Wanna do a 54 Chebby next? keep the pics coming
    nevermind the haters
  6. chaddilac
    chaddilac
    Hey Ian... looks like the trunk frame is welded to the frame? won't it be tough to take it off the frame later on? Or will it crack from movement? Looks great btw!
  7. axle
    axle
    from Drag City
    Alex Gambino is sexy
  8. Ian Berky
    Ian Berky
    HAHA!! Thanx bro!! If you were closer i'd do it!!
    Hey man! Yes the frame is tacked to the frame and it'll be fine. The owner told me to go ahead and weld the gas tank frame to the frame so i did!!! This body will NEVER be off this frame, And if it needs to there are 5 spots that need to be cut or ground down. I know it would be better to have the body mounts mounted to the gas tank frame for absorption, but this is what it is. Im just trying to help to get this car a step forward on a freebie!!
    Thanx bro!!
  9. Ian Berky
    Ian Berky
    :confused::confused:
    :D
  10. cafekid
    cafekid
    ian,
    first off very nice work so far i really like the install and the new trunk pans. my only concern is the pans being welded to the frame...... now i know this is a freebie for a buddy and this is the way he wanted it but it is not a good idea too mount it this way. since the rest of the car is rubber mounted, just driving the car down the road will eventually tear the floors right out of the car, and it will not take long to do. it will save you and your buddy much grief if you can talk him into bolting the floors down rather than welding again not knocking your work just a little help from a fellow hamber. keep up the good work man
    RC
  11. shoeboxsean
    shoeboxsean
    now thats slick as owl shit:)i wish my welds were that good:confused:
  12. Ian Berky
    Ian Berky
    Good call!! Thanx RC!! I'll mount some tabs at the bottom of small posts tomorrow and put thick rubber in between the frame and the tabs!! Actually pretty simple stuff... Should have done that in the first place since i have all the stuff in the garage!!:(
  13. shoeboxsean
    shoeboxsean
    hey ian do you have pics of your drive shaft tunnel being raised for the trans
  14. Ian Berky
    Ian Berky
    I started on the back seat panel late today and my work will be done after i finish the area around the top bars. I'm passing the puck to somebody else for the rest of the floors. Long story short..... somebody else did some work on the front floors and it will be a big job to do them over as they're really messed up and that also includes the front body mounts. Got other stuff going on early next week..... A Chevy coupe chop!!!
  15. shoebox1950
    shoebox1950
    Those are spot welds, not an actual bead. Just because they flow together and are "cherry red" and getting some penetration, doesn't mean you have a strong individual bead. Your weld should have a nice strength vein down the middle as each weld blends together. Looks like you are simply buzzing (pulsing) the welds and more concerned with how pretty they look. How do you know your welds are strong? Have you strength tested them? I like to lay a continuous bead at least 4-6" in length and then the next...to control warpage but still maintain proper penetration. It seems like you are pretty snappy to defend your welds, while at the same time admitting you are new at doing it??? Whether you're building a cruiser or dragracer, your frame/suspension welds should be superior in strength.
  16. Minewithnoshine
    Minewithnoshine
    ^^^ My thoughts exactly. The fab work looks great, but you should be more focused on a proper weld bead for strength and penetration. You can still do a proper weld and have them look great. Not knocking your work at all, but you said you're new too welding so just take all criticism constructively!
  17. Ian Berky
    Ian Berky
    I understand!!
  18. resqd37Zep
    resqd37Zep
    from Nor Cal
    I have to agree with that but Damn they are pretty to look at!:D
  19. Sellers Equipped
    Sellers Equipped
    from San Jose
    I would have told him he's trippN!! to have it welded to the frame. Hey!! I sat up on the Top of Pass on 5 with a Case of beer you never showed! hahah ~S stuff is on its way.
  20. Ian Berky
    Ian Berky
    I understand, I'm definitely open to constructive criticism. I have shown how i weld my suspension parts to a friend and he's a VERY well respected member here on the HAMB and what i'm doing i'm told is very safe and i should not worry about KILLING somebody!!:mad:
    I'm done!!
  21. Ian Berky
    Ian Berky
    HAHA!!! You gonna be at Santa Maria??? Or Mooneyes?? We gotta make this happen.... And I'm known to always be last man standing!!:D
    Thanx Steve!!:):)
  22. Sellers Equipped
    Sellers Equipped
    from San Jose
    I've never even been to either one! hahah guess its time to make chit happen,, Soo if I'm laying down drinking does that mean I'm still in! hahah Hope your well bro.
  23. Ian Berky
    Ian Berky
    HAHAHA!!! You rule bro!!! Let's make it happen!! GOOD TIMES!!!
  24. MUNCIE
    MUNCIE
    from Houston
    Ian,
    Nice shots of the trunk coming together looks smooth man.She is coming along nicely!!
  25. Splinter
    Splinter
    Like the Gussets on the rear suspension. Didja get those from Queen City Steel? I usually clen them out when I go in....
  26. shoebox1950
    shoebox1950
    hmmm...welding the body to the frame???? holy shit...
  27. Ian Berky
    Ian Berky
    Thanx man!
    IMS... They're expensive!:eek:
    Don't be a fucking dick!! If you read what my prior response to CafeKid, It'll be corrected tomorrow!! You Fucking Dick!!
  28. shoebox1950
    shoebox1950
    I'm not bein a dick...I just think it's silly to post things on here that you KNOW are not done correctly...and then people replying "nice fab work" over and over...what is your point in doing that?? Do it right, especially when you know you're not doing it right...I just don't understand your reasoning...nor do I care anymore...you are way too defensive pal...jeezus...remind me to not look at any of the shit you post anymore...you seem to know IT ALL.
  29. LabRat
    LabRat
    Take a deep breath ..... And forgive , half these guys don't even realize that you almost finished the chop while they were bleating about your fab and welds ......
  30. Ian Berky
    Ian Berky
    There's definitely better ways to tell somebody they're doing something wrong rather than humiliate them you could learn something from somebody like CAFEKID. What? Did you really think i was just gonna be nice to you?? You fucking douchebag!! What the fuck have you done that's so good or ANYTHING at all, if you have you're definitely not sharing !
