Projects 49 Plymouth chop
Discussion in 'The Hokey Ass Message Board' started by Keeney, Sep 17, 2014.
  1. Keeney
    Keeney
  2. Keeney
    Keeney
    Paint cleaned off and ready to make a plan. ImageUploadedByH.A.M.B.1410995135.408227.jpg ImageUploadedByH.A.M.B.1410995176.891953.jpg ImageUploadedByH.A.M.B.1410995241.842400.jpg topless
  3. 41 C28
    41 C28
    Wow! keep the pictures coming.
  4. Keeney
    Keeney
    ImageUploadedByH.A.M.B.1411055402.426258.jpg ImageUploadedByH.A.M.B.1411055701.259258.jpg ImageUploadedByH.A.M.B.1411055756.475753.jpg ImageUploadedByH.A.M.B.1411055810.042505.jpg
  5. Keeney
    Keeney
    ImageUploadedByH.A.M.B.1411055877.942752.jpg ImageUploadedByH.A.M.B.1411055929.592662.jpg ImageUploadedByH.A.M.B.1411056032.026191.jpg ImageUploadedByH.A.M.B.1411056099.225815.jpg ImageUploadedByH.A.M.B.1411056132.342646.jpg ImageUploadedByH.A.M.B.1411056178.959576.jpg
  6. That dont look like any 48 that I ever saw
  7. Keeney
    Keeney
    Because it's not. Typo. Actually 49
  8. jreeder41
    jreeder41
    Looking great!
  9. Keeney
    Keeney
    Thanks
  10. Keeney
    Keeney
    ImageUploadedByH.A.M.B.1411314264.752158.jpg Rear window frame in place. Cut off excess and butt weld. I would raise the seam a little bit more next time away from the frame but the lines met so well there I went with it.
  11. Keeney
    Keeney
  12. Keeney
    Keeney
    ImageUploadedByH.A.M.B.1411314905.189505.jpg Now everything is tacked in place the rear quarters can be cut to fit. A few pie cuts and they're in. Cutting in half was not actually needed. The second side is usually the funnest because you now know your plan of attack. ImageUploadedByH.A.M.B.1411315066.223067.jpg ImageUploadedByH.A.M.B.1411315113.456177.jpg This side went great and fit snugly.
  13. Keeney
    Keeney
    ImageUploadedByH.A.M.B.1411315438.339700.jpg Then you can tell that my fill pieces are small and easy to make. Trimmed up the back window section at the body line but not too much or when you pull it out later for the bottom patch it will be short. ImageUploadedByH.A.M.B.1411315642.256510.jpg Here you can see the little gap that I'm talking about. Bottom of the window section. I just used a scrap piece from electric shears to weld in.
  14. Keeney
    Keeney
    ImageUploadedByH.A.M.B.1411315873.873148.jpg back to the rear filler piece. This was the hardest part of everything actually. Transitioning from the deck lid into sail panel while minding the rear quarter fender curvature. If the filler piece just follows them it'll have a canyon under the rear window and look stupid. Finding the right angle took awhile. You know when you find it.
  15. Keeney
    Keeney
    ImageUploadedByH.A.M.B.1414083470.344039.jpg ImageUploadedByH.A.M.B.1414083498.943957.jpg ImageUploadedByH.A.M.B.1414083521.843899.jpg
