49 plymouth help
Discussion in 'The Hokey Ass Message Board' started by rockin562, Apr 13, 2009.
  1. rockin562
    rockin562
    where can i get a set of dropped uprights for my plymouth with stock brakes?
  2. Slick Steve
    Slick Steve
    from Indy
    Only place I have seen them is Fatman Fab. I think you may HAVE to use disc up front tho. Can I ask why you want to keep the original brakes?
  3. RodStRace
    RodStRace
    Ply-Do has em, I think.
    They do not have a web presence, and the owner passed on last year.
    304-475-3245!
    PLYDO RT.1 BOX 277-B DELBARTON, WV 25670
  4. 390kid
    390kid
    fat man has them but they're spendy. and you have to heat and bend the steering arms. you can get a 2" drop by moving the spring plate on the lower control arm to the bottom and cut a coil off the spring and you end up with like 4" off drop. the steering is so fucked on those its no hardly worth putting spindles on.
  5. rockin562
    rockin562
    well im baggin the car but i just want to make sure i can get it all the way in the weeds. the bottom arm plate im making a new one to mount the bag on and its going to be on the bottom of the arm.
  6. tankwilson
    tankwilson
    Here is my 49 bagged with stock spindles. This past winter i C notched the frame over the rearend and now it will lay frame in the rear. I haven't done the front yet because the oil pan will drag if i do.
