Projects 4BANGER mild HotRod
Discussion in 'Traditional Hot Rods' started by Deutscher, Nov 12, 2024.
  1. Deutscher
    Deutscher
    from Germany
    Thank you for taking a look.
    Greetings Harald
    Sharpone likes this.
  2. Deutscher
    Deutscher
    from Germany
    The engine is ready for installation. Regards, Harald
  3. rwrj
    rwrj
    from SW Ga
    You know, it's a small thing, but chamfering the edges of that oil filter bracket is the kind of detail I really admire about how you do stuff. That engine looks perfect. I really like the color, too.
    jet996, winduptoy, marioD and 2 others like this.
  4. marioD
    marioD
    Looks great! Love the color what brand did you use?
    winduptoy, Deutscher and Sharpone like this.
  5. Deutscher
    Deutscher
    from Germany
    This one comes from the bay.
    Regards Harald
    winduptoy, LCGarage, marioD and 2 others like this.
  6. marioD
    marioD
    Thank you Harald!
    Sharpone and Deutscher like this.
  7. Deutscher
    Deutscher
    from Germany
    The engine is now installed.
    I had already tried installing it last week, but there was no clutch play in the release bearing.
    The bearing hub had to be shortened by 7mm to create enough play for adjustment.
    Now I was finally able to connect it, and the engine is in place.
    The clutch is now working properly.
    I still need to rework my exhaust manifold, as one pipe is only a few millimeters above the wishbone.
    Regards, Harald
    winduptoy, Dannerr, jet996 and 9 others like this.
  8. Sharpone
    Sharpone
    The engine looks good in its home.
    Dan
    winduptoy and Deutscher like this.
  9. Deutscher
    Deutscher
    from Germany
    Ha, there's one more thing I have to tell you. When I first installed the engine and then noticed that the release bearing was pressing into the clutch, I couldn't turn the engine over. Since I had to take the engine out again, I wanted to take a closer look. Sure enough, it wouldn't turn. I was sweating bullets; I didn't know what I'd done wrong. First, I took the cylinder head off. Nope, that wasn't it. I put the head back on. I removed the drive shaft that drives the distributor and oil pump. Nope, still stuck. Flywheel... maybe the mounting bolts were too long? I couldn't imagine that; they were the ones that were already installed. I took it out anyway, still not free. Now things are getting weird. The engine turned over before without the flywheel, so I removed the flywheel, and now I could turn the engine over, but I couldn't see anything wrong. Then, while installing the flywheel, I noticed something was stuck. I shone a light on everything and saw that the cotter pin in the flywheel housing had jammed in the flywheel gear ring and was being pulled in.
    Normally, it's bent open quite far and couldn't move at all, but this one did. I corrected the problem, tightened the flywheel, and the engine turned over perfectly. It's a good thing I had to take the engine out again; otherwise, I would have been searching forever.
    Regards, Harald
    Outback, winduptoy, Dannerr and 11 others like this.
  10. rwrj
    rwrj
    from SW Ga
    Something like that happened to me when I first tried to get mine running. The bolt holding the old -fashioned flat spring on the bendix sheared and dropped its head down into the bellhousing. Jammed in the ring gear and locked her up. Took me a bit of puzzling to figure out what was going on, as well. Something about how it was lying, it would only jam when I rotated the engine the proper direction, so I pulled the plugs and stuck a magnet to the flywheel through the starter hole, rotated the engine backwards one full spin, and there it was. Along with 3 more from who knows when. Hahaaa.
    Your car is outstanding, as is your work.
    winduptoy, LCGarage, RMR&C and 4 others like this.
  11. 4BangerDean
    4BangerDean
    I thoroughly enjoy this thread. I really like what you're doing with your A.
  12. Deutscher
    Deutscher
    from Germany
    I had rebuilt the water pump; the new shaft needed to be shortened and adjusted so everything would fit together.
    The exhaust manifold was sitting too low and needed to be raised, so I cut everything apart, removed about 3/4 of the pipe length, welded it all back together, smoothed it, and applied another coat of black heat-resistant paint.
    I then made the angled clamps to bolt the intake and exhaust manifolds together.
    I installed the distributor, but unfortunately, the ignition coil cable is much too short.o_O
    I just noticed that the ignition coil needs to be reversed.:D
    The Weber carburetor was also installed, and the throttle linkage was adjusted.
    That's it for now.
    Regards, Harald
  13. Deutscher
    Deutscher
    from Germany
    Lots of little things done, which really takes up a lot of time. The throttle gas pedal ***embly is mounted, connected to the carburetors, and adjusted. Both throttle valves open, very nice. New spark plugs are installed and the coil is properly attached. Now everything fits.
    Air filter on, so that's it on the carburetor side. Now to build the bracket for the new alternator, then install the alternator and attach the tensioning bracket.
    Done, good.
    Greetings Harald
    Okie Pete, jet996, winduptoy and 11 others like this.
  14. rwrj
    rwrj
    from SW Ga
    Almost ready to fire it up. Exciting times. It looks fantastic.
    winduptoy, Sharpone and Deutscher like this.
  15. Deutscher
    Deutscher
    from Germany
    Thanks, there are still so many things to do.
    I noticed that the brake rod from the pedal to the crossmember isn't activating the brake light switch, so I'll readjust the brake system tomorrow so it works.
    I have to install a completely new electrical system; we're required to have a functioning hazard warning system, which is another challenge.
    Regards, Harald
    marioD, winduptoy, RMR&C and 2 others like this.
  16. rwrj
    rwrj
    from SW Ga
    Harald,
    Have you seen this YouTube channel?
    I think even I could wire a car successfully with their help. Haha. One of the many advantages of living where I do is that old cars are only required to run the safety equipment they were originally equipped with. It's a practical advantage but, as I have found out the hard way, not always a safe one. I don't know if I will bother with hazard lights on my speedster rebuild, but I will certainly have turn signals and more than one brake light. Good luck, and thank you for posting your wonderful work.
    chlsnk, Okie Pete, jet996 and 6 others like this.
  17. Deutscher
    Deutscher
    from Germany
    No, I don't know him.
    Thanks for that.
    I can handle the electrical work, it just can't be done in a day.
    Regards, Harald
    Sharpone, marioD, winduptoy and 3 others like this.
  18. Deutscher
    Deutscher
    from Germany
    Because my radiator was leaking,
    I had a cheap aluminum radiator shipped from the USA, blackened it, and installed it.
    It fit the frame fine, but... the radiator shroud doesn't fit over it; the upper water tank is much too high/wide at the front. So I've decided to get my radiator repaired.
    I'll probably have to sell a kidney:(, but it has to be done.
    Cheers, Harald
    Okie Pete, marioD, Sharpone and 2 others like this.
  19. Where's the leak?
    I had good luck (saved money!) by just changing the bottom tank on a spare rad for my "12'eren", instead of recoring the old, leaky one. Maybe I'll be able to help? Will go have a look in the garage immediately to see, what I've got. :)
    jet996, marioD, Sharpone and 2 others like this.
  20. Deutscher
    Deutscher
    from Germany
    Thanks, the mesh had several leaks which I resoldered, but now it's leaking at the top of the tank under the side panel.
    That panel would have to be completely removed for repair, and since I don't know the condition of the internal core. I'm having it refurbished.
    No one is giving me a precise price; they all just want to inspect the radiator. Regards, Harald
    Okie Pete, Dannerr, marioD and 3 others like this.
  21. rwrj
    rwrj
    from SW Ga
    Hope they don't say both kidneys. Good luck.
  22. winduptoy
    winduptoy
    like how this is turning out...
    sorry for the radiator problems, but keep it in perspective....a crummy radiator and loss of coolant could inadvertently overheat your new engine .....you will appreciate the investment in the future though painful now...
    carry on banger brother
    Okie Pete, jet996, rwrj and 2 others like this.
  23. I’ve got 4 spares, all in need of differet repair- but haven’t checked for leaks. Let me know, if you want me to!
    It’ll be another old radiator, with unknown durability, but at least you’ll be driving!
    I got quotes from different danish suppliers, lowest were Aabenraa http://www.koeler.dk/(nearest DK/D boarder) for just under €700,-. And that was an early A, later A’s are usually cheaper to recore. :)
    Sharpone, winduptoy and Deutscher like this.
  24. Deutscher
    Deutscher
    from Germany
    Thanks, that's incredibly kind of you.
    If things don't work out here, I'll gladly take you up on your offer.
    The local radiator spe******t wants €1700 plus tax, so about €2000, which is roughly $2300.
    I'll pick up the radiator again on Monday. Even if I ordered through Snyders, it would only cost me about €1300, including shipping and tax.
    I have three more addresses, two of them in the Leipzig area, that I'll contact.
    We'll take the Mustang there and have a nice trip. I'll keep you posted.
    Cheers Harald
    Outback, Sharpone, RMR&C and 2 others like this.
  25. UK holiday Harald - there's a couple of places near here that would be way cheaper for a recore.
  26. winduptoy
    winduptoy
    good reason for a drive....I totally understand your reasoning for a 'second opinion'....good luck
  27. trikejunkie
    trikejunkie
    from Scotland
    £300 for a re core in Scotland ! Pop over for a holiday !
  28. Deutscher
    Deutscher
    from Germany
    Thanks guys, I really appreciate it.
    We've always enjoyed our holidays in England/Scotland; they've been wonderful trips with fantastic people, and we'd love to come back.
    We picked up the radiator today and took it to the radiator repair shop in Leipzig. They were very pleasant to deal with, and the €750 price tag and 14-day wait were perfectly acceptable.
    Cheers Harald
    Sharpone, LCGarage, winduptoy and 4 others like this.
  29. winduptoy
    winduptoy
    always good to find a reasonable solution....
    I was going to offer the slightly used 2 row/10 fin per inch one I have....come on over and pick it up...we will run some of US66 in a banger and make it a day....
    I remember (sounding like an old geezer now) where every solution to a car problem was $20
    then $100.....now magnitude more....
    Hopefully a drive for you soon.....
    Sharpone, Deutscher and Dannerr like this.
  30. Deutscher
    Deutscher
    from Germany
    Yes, that would be a dream, thank you for your offer. There's hardly anything better than driving along that dream road. Today I readjusted the brakes so the brake light switch works, opened the brake light switch, cleaned and re-greased it,
    fitted the upper floorboard with new floorboard sealant and installed it.
    I also installed both front fenders. Unfortunately, no pictures; I forgot my smartphone at home.
    I'll post new pictures tomorrow.
    Greetings, Harald
