4bbl holley on 350 sbc/ leaking from top rail of carb
Discussion in 'The Hokey Ass Message Board' started by 56 ford custom, Jul 29, 2012.
  1. 56 ford custom
    56 ford custom
    from Socal
    So the idle screws are the ones on the side of the metering block on front of carb correct?
  2. Master of None
    Master of None
    Yes, and when you turn the screws in, do not over tighten them! When you start to feel them getting snug, stop!
  3. 56 ford custom
    56 ford custom
    from Socal
    Ok, let me try doing this real quick then. I noticed the vacuum modulator on trans is the correct one but its the newer style one and the ****** for the vacuum hose us smaller or harder to get a hose onto and doesnt fit aswell as the old one.
  4. slammed
    slammed
  5. slammed
    slammed
    Use lube (!) to slippy dat beach.
  6. 56 ford custom
    56 ford custom
    from Socal
    Well I checked and the vacuum hose on the modulator is way bigger then the inlet vacuum source on the carb. So I am going to have to figure something out.
  7. RWENUTS
    RWENUTS
    from Nanaimo BC
    Use a full length of 5/16 vacuum hose. It'll fit on the carb and with a little spray of wd40 in the end of the hose then the hose should slip on the vacuum modulator ******.
  8. slammed
    slammed
    Y'all check the latest Youtube clip? When those screws are SET at maximum vac level (in gear, foot brake held) you will likely have to re-set the float level. These are key. You list your changes on a large sheet of cardboard. Itemize each step done.
  9. 56 ford custom
    56 ford custom
    from Socal
    Ok I will grab some of that hose after work tomorrow. So switching the hoses around and what not...What does that test?
  10. RWENUTS
    RWENUTS
    from Nanaimo BC
    Possible vacuum leaks.
    Don't worry about fine tuning your carb yet! That's for later.
  11. 56 ford custom
    56 ford custom
    from Socal
    I just wish someone lived closer to help me knock this out
  12. 56 ford custom
    56 ford custom
    from Socal
    So the 5/16 line will go from modulator to the vac ****** under the front fuel bowl? The smaller ******?
  13. RWENUTS
    RWENUTS
    from Nanaimo BC
  14. 56 ford custom
    56 ford custom
    from Socal
    Well I started the motor this morning to move the car and I have to keep in the gas and rev it so it doesn't die. An old timer told its most likely too retarded?
  15. RWENUTS
    RWENUTS
    from Nanaimo BC
    Was the motor still cold or did you let it warm up a bit?
    You have no choke!
  16. slammed
    slammed
    Take some pix of your carb, hoses, distributor, and over all engine shot.
  17. 56 ford custom
    56 ford custom
    from Socal
    I'm going to take a shot of the motor when I get home after work. I trie dwarming it up the best I could since it keeps dying and seems like timing
  18. 56 ford custom
    56 ford custom
    from Socal
    Well I did all what you guys told me and the motor starts but I have to punch the gas and stay on it or it dies right away.
  19. RWENUTS
    RWENUTS
    from Nanaimo BC
    Is that when it's cold?
  20. slammed
    slammed
    You have a tach? Set the idle to where it will not die. How fast is that? Does it maintain the idle w/out having to feather it? The idle circuits may have debris in them. It was/is imperative that during the tear down they were blown out. Really, it should have had a kit (unproven carb) put in to it while it was apart.
  21. 56 ford custom
    56 ford custom
    from Socal
    Yeah I went through it and put all new gaskets and seals. Guess it wasn't good enough
    If anyone here is near me in SOCAL please PM me and maybe we can meet up and get this car running.
  22. slammed
    slammed
    Did you blow out the idle circuits.? We know the gasket and rings deal.
  23. 56 ford custom
    56 ford custom
    from Socal
    I blew out the Carb the best I could
  24. RWENUTS
    RWENUTS
    from Nanaimo BC
    Where's the pics!!
  25. 56 ford custom
    56 ford custom
    from Socal
    I will try and post the pics in a little bit. I have a question so I shouldn't have the vacuumhoses teed off at all right?
  26. slammed
    slammed
    Look. Helter Skelter is going on. Stop it. Hook up all vac hoses. One hose goes to the carb (ft bottom) from the distributor. Check? One goes from trans module to intake, check? They must be snug to fitting.
  27. 56 ford custom
    56 ford custom
    from Socal
    Check...but the trans module is teed with the booster then goes to intake then the PCv is on the rear of p***enger valve cover and goes to base of Carb at the rear p***enger side
  28. slammed
    slammed
    WHOA! One: the distrib-to-carb ****** at front of carb. Done?
  29. 56 ford custom
    56 ford custom
    from Socal
    That is hooked up too
  30. Commish
    Commish
    from NW Ok
    You really need somebody with a little knowhow to give you a little hands on help. If nobody close comes forward and you have a little time try this. Find the idle screw on the front corner of the carb that opens the primary throttle plates, screw it in a turn or two, unplug the vacuum advance hose and plug the port on the carb. Now get a 9/16 end wrench and loosen the hold down bolt a little bit at the base of the distributor, grab a hold of the vacuum advance can and pull it towards you about a 1/4 ". Now try to start it, if you can get it to start and run, even if way to fast, you can then start to feather the idle speed screw back down. If you can get it to stay running then play with the timing a little, and get it to a slow rpm, if you make it that far then plug the vacuum advance line back on, if you have the base timing half way close the engine will speed up and smooth out, then you can back the idle down a little more. If the above don't work try moving the distributor a little the other way, would not hurt to put a chalk mark or something on the manifold to go by before you start moving it.
