4bbl holley on 350 sbc/ leaking from top rail of carb
Discussion in 'The Hokey Ass Message Board' started by 56 ford custom, Jul 29, 2012.
  1. 56 ford custom
    56 ford custom
    from Socal
    Are you saying I should replace gaskets and torque down in that sequence?
  2. slammed
    slammed
    No, just tighten them for now. Then check around the ports for a leak while it is running. Carb spray. See if any kind of bubbling happens. Check your carb base nuts as well.
  3. 56 ford custom
    56 ford custom
    from Socal
    Yes thats what I did monday night and its still the same.
  4. RWENUTS
    RWENUTS
    from Nanaimo BC
    Is that a spreadbore intake? Or just a square bore type.
    That fancy pcv with the hose to the carb might be a vacuum leak too!
  5. slammed
    slammed
    It must fit snugly, like all the vacuum lines. Is the modulator connection tight? We should make a check list and thoroughly go down it, one by one...I went through the same drill when 1st getting my Impala back on the road. The same vac/carb issues.
  6. 56 ford custom
    56 ford custom
    from Socal
    Ok I guess we can make a check list then.
  7. 56 ford custom
    56 ford custom
    from Socal
    Alright guys whats the check list you made for me?
  8. 56 ford custom
    56 ford custom
    from Socal
    For the morning crew! So where should I start off on this situation to solve the "vacuum leak"
  9. RWENUTS
    RWENUTS
    from Nanaimo BC
    Patience gr***hopper!!
    We'll let slammed give you a list!!
  10. 56 ford custom
    56 ford custom
    from Socal
    Ok I will try. Ill wait for his list.
  11. 56 ford custom
    56 ford custom
    from Socal
    Been super busy and hopefully can make some head way on the car this weekend. Got to get a list made and get the bugs worked out. Anyone?
  12. RWENUTS
    RWENUTS
    from Nanaimo BC
    Have you set the float levels correctly?
  13. 56 ford custom
    56 ford custom
    from Socal
    Yes I have. rock the car and a little fuel comes out of each bowl.
  14. RWENUTS
    RWENUTS
    from Nanaimo BC
    Good! Floats are set.
    Have you had the carb off the intake?
  15. 56 ford custom
    56 ford custom
    from Socal
    Yes I have, I replaced all the gaskets along with the base gasket.
  16. Master of None
    Master of None
    Have you checked the timing since you have hooked up the vacuum advance? I looked and didn't really see if you found out if the vacuum canister is shot.
  17. RWENUTS
    RWENUTS
    from Nanaimo BC
  18. 56 ford custom
    56 ford custom
    from Socal
  19. RWENUTS
    RWENUTS
    from Nanaimo BC
    Was there one gasket or 2 gaskets with a thin plate between the carb and intake?
    What is the name on the intake?
    Do you have a pic of the old gasket you took out?
  20. 56 ford custom
    56 ford custom
    from Socal
    Im pretty sure its called "Street Dominator" There is no plate between carb and intake just a gasket, I do not have a picture of the old gasket.
  21. RWENUTS
    RWENUTS
    from Nanaimo BC
  22. swade41
    swade41
    from Buffalo,NY
    That intake came both ways, this one is a spread bore type with a spread bore Holley on it
    same intake but square bore with an Edelbrock on it
  23. RWENUTS
    RWENUTS
    from Nanaimo BC
    I stand corrected!
    Lift up your carb and check first.
  24. 56 ford custom
    56 ford custom
    from Socal
    Im not saying any one of you are wrong but it would really need that adapter?
  25. swade41
    swade41
    from Buffalo,NY
    If he had a square bore carb on a spread bore manifold, sure he would. The square bore is not big enough to cover the spread bore's hole. If you try it the other way, spread bore carb on a square bore intake, the secondary throttle plate can't open because the manifold hole is to small.
  26. 56 ford custom
    56 ford custom
    from Socal
    Ok here is my intake, do I need that plate with the intake/carb set up I have?
  27. RWENUTS
    RWENUTS
    from Nanaimo BC
    Yes! Most definetly!
    That's the spread bore style intake.
  28. 56 ford custom
    56 ford custom
    from Socal
    So I am definitely gonna have to buy that plate kit then? I was checking Autozone and Oreilly so I could get them local but im not seeing them
  29. RWENUTS
    RWENUTS
    from Nanaimo BC
    Yup you'll need the adaptor. You must have some speed shops in your area besides the parts stores.
    Let us know when you get it ready to install and we'll give some tips on carb installation. Then we'll get you fixed up on your vacuum pot on your distributor and your timing and carb tuning.
    Do you have a vacuum gauge and a timing light?
  30. 56 ford custom
    56 ford custom
    from Socal
    I have searched for some local speed shops and nothing comes up. I don't have a vacuum gauge or timing light either unfortunately.
