Technical 4inch block drop on 52 lincoln
Discussion in 'Traditional Customs' started by GreaseNgears, Jan 25, 2016.
  1. GreaseNgears
    GreaseNgears
    I just put in 4inch blocks in the rear end of my 52 Lincoln.. sits pretty damn low.. pretty happy with the stance.
    I took it around the corner and my front end is kind of squirly ... . Im ***uming because the rearend is dropped so much. I was going to lower the front about 2 inches by cutting the coils just havnt done it yet. Will that fix the front end being squrily ... Anyone else have this problem. ? Thanks
  2. I think you have bigger problems. Cutting coils will only make it worse.
  3. GreaseNgears
    GreaseNgears
  4. Jalopy Joker
    Jalopy Joker
    so it was OK before lowering? Jamco Engineering sells a '52-'55 kit
    Jonnie King likes this.
  5. GreaseNgears
    GreaseNgears
    Yes...it was good before lowering.
  6. Jonnie King
    Jonnie King
    from St. Louis
    Jalopy Joker is right...Jamco has a good kit to cover this.
    REMEMBER: That Lincoln is VERY heavy, and, it's very old. Cutting the existing stock coils, as chopped51 has also stated, would not be advisable.
    With that 4" drop in the rear the weight of the car has shifted, that's probably why it's "motorboating" on you. PLUS, the rear shocks, etc., need to be addressed also so that you don't "bottom out", or cause problems with hitting your driveshaft. (And, make sure your front end is rebuilt too: shocks, bushings, stabilizer links, etc.)
    I love the '52-'54 Lincolns, and yours will turn out cool...just make sure your entire suspension is gone over so that you'll be safe at all times. Looking "cool" is one thing, staying alive is another.
    Jonnie www.legends.thewwbc.net
  7. Finnrodder
    Finnrodder
    from Finland
    Well,it takes forever to get your goods from Jamco.
    Few yrs ago i bought a pair of 4" drop leafs for my shoebox from St.Louis spring company.
    They got pretty nice and fast service and pricing was good too.And i bought a pair of 4" drop leafs for my friends '52 Mercury too from them.
    I have never liked the idea of cutting coils,guys used to do that **** a lot when i was a kid in my neighborhood.It was called "the hitachi lowering kit" back then:D
    Anyway,1990 Ford Aerostar coils will be a better choice for you than cutting the coils.
    The Aerostar coils arent far away from Jamco's stuff,only the price tag will have smaller numbers on it.
  8. scott51
    scott51
    You got the alignment re-done after you lowered it right?
    Also 4" blocks aren't really the best option on any car, if your springs are in ok shape have them re-arched by a spring shop then use blocks to fine tune (3" max)
  9. Rusty O'Toole
    Rusty O'Toole
    Lowering the rear can throw off your caster. You need to do whatever you plan to do on the front, then get an alignment.
  10. Zuffen
    Zuffen
    from Sydney
    Rusty has it in one.
    Clearly a caster problem.
  11. 4" blocks in the rear are allowing the rear springs to deflect sideways when you turn. This is causing oversteer. If you are bound and determined to keep those blocks, you have to use a panhard bar to hold the axle centered under the car. Don't worry about the front end yet!
  12. jimmy six
    jimmy six
    Extra caster will make it harder to steer and makes the car come back to straight easier that's why we add caster to our LSR race cars.
    Not positive on the Lincoln but on the Fords you can remove some rivets on the front lower A arms and add blocks to raise the spindle and not cut or put in new springs.
    If you know the inner and outer diameter of the fronts I can tell you whether Ford AeroStars will fit. They lower about 1-1/2 to 2" .....
