4wheel disc MC???
Discussion in 'The Hokey Ass Message Board' started by airbrushguy, Aug 26, 2010.
  1. airbrushguy
    airbrushguy
    from NJ
    What year corvette is it that everyone seems to use the master cylinder from? The one with the cover that is round on both ends. I think it's in the '70s.
  2. airbrushguy
    airbrushguy
    from NJ
  3. Toast
    Toast
    from Jenks, OK
    69 will be round at both ends
  4. airbrushguy
    airbrushguy
    from NJ
    Without taking them apart, how do you know 1"bore from 1 1/8" bore?
    Thanks
  5. firemancooter
    firemancooter
    I believe 68-82 should all have the same master cylinder for 4 wheel disc brakes. Note sure on the bore size.
  6. Pull the rubber boot off the end and measure the opening.
    Charlie
  7. fab32
    fab32
    What charlie said. Around a '68-'70 should get you a disc/disc unit.
    Frank
  8. zman
    zman
    from Garner, NC
    Mine is a '68
  9. V8 Bob
    V8 Bob
    All Corvette dual masters from '66-up are disc/disc.
  10. coolbreeze1340
    coolbreeze1340
    from Indiana
    What V8 Bob said! Don't forget if you are mounting it under your car it will be "backwards", so the rear port goes to your fronts, and the front port will go to the rears. Don't ask me why it makes a difference but it does.
  11. zman
    zman
    from Garner, NC
    I just picked '68 out of thin air when I was asking for a manual disc/disc m/c
