4x1 hemi intake
Discussion in 'The Hokey Ass Message Board' started by sport fury, Dec 12, 2010.
  1. sport fury
    sport fury
    i have a weiand wc245 4x2 intake manifold. i want to run 4 single barrel 2 bolt carbs on it. i have found a source for the carb adapters. i seen a post where someone used the same adapters to run 4 single barrel rochester carbs on a simular weiand 4x2 intake on a desoto hemi. he said it idled very well. he did not get a chance to test it on the street before he sold the car. i would like to run 4 single barrel stromberg carbs. has anyone ever used single barrels on this intake. if so what were the results.
  2. sport fury
    sport fury
  3. stillrunners
    stillrunners
    from dallas
    seems there is an old intake (with 4 - strongberg carbs) with that set up...not sure of the part #....do a thread search...
  4. George
    George
    "Kerry" on here made up a plenum box that he bolted onto a 4X2 Weiand so he could run progressive linkage. Said it ran good with decent MPGs, 4 1 brls should work that way also.
  5. ME I would mill out the centre and make a four single plate and weld it in.
  6. George
    George
    You could, but if it don't work you've permanently devalued(ruined?) a valuable intake.
  7. 73RR
    73RR
    I seriously question the available airflow through a 1-bbl. Yes, it will work, and the engine will run ok, (truck and marine intakes had a 2x1 intake available) but for the final value of labour and material I doubt it will be a good move unless you have low expectations of the finished product.
  8. George
    George
    Not A 1 bl, but 4 of them.
  9. 73RR
    73RR
    I understand that there would be 4 of them...but they are still 1-bbls. Do we have a clue what the venturi and ****erfly diameters are?? Even if they are some kind of giant 1-bbl units and actually flow some air they are also likely to be a bit primitive, design wise.
    I really think it will be a wheezer.
    If he OP does not have high expectations then it might be just perfect.
    Perhaps I am just approaching this from the wrong angle, not the first time and I'm sure it won't be the last.
  10. ClimisCD
    ClimisCD
  11. George
    George
    On that recent 2X1 thread someone was claiming use on a Bonnieville car, but you know how that is...but if a 2X1 worked, a 4X1 should also. Was the 2X1 used on fire trucks, or was that a rumor? If so they tend to move along!
  12. sport fury
    sport fury
    i will be using 4 offenhauser carburetor adaptors. offenhauser part number 3858 or 3859 depending on which selection of single barrel carburetors will match up to either of these 2 carburetor adaptors. 331 hemis used factory 2 barrel intake manifolds and ran just fine. i would think just about any combination of single barrel automotive carburetors would be of suffient cfm or greater. i am not building a race engine. i just want the engine to perform within reason for street use. for me i just want the engine to sound and look good with fair fuel economy. all 3 bolt 2 barrel carburetors are way too expensive or they have vacuum power valves.
  13. sport fury
    sport fury
  14. Nixer
    Nixer
    maybe this will change your mind about 4 single barrels...tok
    <object width="640" height="390"><param name="movie" value="http://www.youtube.com/v/8me-0YfI5j4&hl=en_US&feature=player_embedded&version=3"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/8me-0YfI5j4&hl=en_US&feature=player_embedded&version=3" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="390"></embed></object>
  15. strombergs97
    strombergs97
    Hello..Strombergs don't have vacuum powered power valves..
    Duane..
  16. scootermcrad
    scootermcrad
    What intake manifold is that?? Just a u-fab jobby?? With the way the carbs are sitting it almost looks like a Cunningham 4x1 intake. Anyone actually have a picture of that intake? Tuck... uh hum!?
    Forgot about that MFS clip...
  17. sport fury
    sport fury
    i did not say strombergs have vacuum power valves.
  18. tubman
    tubman
    All that video shows me is that you can get a hemi running (just barely) on four one barrels by pouring gas into the carbs. What is it with this 4 one barrel ****?:confused: First this, and then another thread with some guy trying to do it on a SBC?
  19. sport fury
    sport fury
    why is this such a problem for you. i don't care for your foul mouth and bad at***ude. please keep this type of reply to yourself. the hamb should be for fun and a person should not have to read nonproductive bad mouthing. there are many things on the hamb i don't care for but i don't knock others for them.
  20. Royalshifter
    Royalshifter
    Moderator
    You guys are from the same state?......come on lets give hugs.
  21. George
    George
    Cunningham did it in the 50s, so it's traditional!:)
  22. scootermcrad
    scootermcrad
    Aw geesh... I give you the Cunningham. 4x1's are indeed traditional. Those intake manifolds even have performance curves available.
    I don't know the design specifics to say WHY it was so successful, but it was.
  23. George
    George
    That ***mingham marine 4X1 is still for sale, owner came up on an old thread I started @ the Hemi.
  24. vrod64
    vrod64
    from Katy,Texas
    Absolutely hilarious ! Then the guy was gonna take a drink !
    Funny. Great video
  25. strombergs97
    strombergs97
    I like the linkage on the Cunningham 4x1..
    Duane.
