Here are some pictures of a 4x2 custom intake for a Hemi with custom built linkage and Stromberg 97s.. This is what I enjoy doing, plus put some $$$$$$$ in my Hot Rod Addiction Fund.. Thought I would share.. Duane.
Great work...Looks good, but..... One question...do you think running them progressive is going to give good fuel distribution to all 8 cylinders at low rpm? Looks like a small plenum and the turns might restrict flow to the end cylinders. But I am sure it is something you can work out.
SOLD... I built this the way the person wanted it.."If" it does run lean the collar can be moved to run them all at the same time..Also, I believe that with the long narrow plenum the two front and rear will have no problem drawing the air and fuel..Small plenum, more velocity & vacuum. This is for a 331ci... Duane..
