4x2 weiand with 97's fuel line routing??
Discussion in 'The Hokey Ass Message Board' started by Vintage Driveline, Jul 4, 2007.
  1. Vintage Driveline
    Vintage Driveline
    Alliance Vendor
    Just racking my brain on how to route the fuel line from the fuel block on a SBC w/ weiand 4x2's without it looking messy?
    Any pic's would help!
  2. tommy
    tommy
    I have a thing for the old hexagonal fuel logs for multiple carbs. They just have that old look and you don't have a bunch of floppy hoses running all over.
    It's pretty easy to make a log type fuel block out of tubing. I got this material at Home Depot.
  3. Dirty2
    Dirty2
    Heres mine , I still dont like it.
  4. strombergs97
    strombergs97
    Hello..I would use banjo fittings on carbs..You'll only have two lines going to your fuel block..The fuel can be for three carbs and the first outlet by the fuel inlet can be your gauge. You'll get accurate readings to your carbs...Just an idea..
    Duane
  5. blt4speedsince79
    blt4speedsince79
  6. blt4speedsince79
    blt4speedsince79
  7. blt4speedsince79
    blt4speedsince79
    here is another one hope they help
  8. blt4speedsince79
    blt4speedsince79
    i used the original fittings in the carbs and cut the flared end off with a tubing cutter and bought some compression fittings for 3/8 lint from the hardware store and then on the other end used compression with male npt to screw into the fuel log. i used stainless tubing for the lines.
  9. Bruce Lancaster
    Bruce Lancaster
    You can simplify that last suggestion even further...
    Get some Ford fittings, still available at NAPA, and a handful of preformed 1/4" brakelines and tees for the same. cut brakelines, slide on Ford fitting on cut end, bend to suit, screw formed end into beake Tee. Everything can be done easily, quickly, and without leaks, and with enough tees you can plumb any number of carbs.
  10. Paul
    Paul
    Editor
    or some original Eelco 90s with rubber lines back to a log on the firewall
    just scored this intake last week, think I should replace the filters or go with the patina :D
  11. tunglegubbin
    tunglegubbin
    Like this.
  12. SinisterCustom
    SinisterCustom
    tunglegubbin....where'd ya get those fittings???? Very clean....
  13. dickster27
    dickster27
    from Texas
    Here is a couple I have done that are a bit different.
  14. tunglegubbin
    tunglegubbin
    Banjo fittings from your local hydraulics shop, welded to pipe
  15. SinisterCustom
    SinisterCustom
    Dickster....that first pic looks good. That's what I was thinking of doing....Is that just brake line? And is that Eelco linkage???
    Also, how are you guys supporting the long throttle shaft extensions????
  16. dickster27
    dickster27
    from Texas
    Sc, that's polished aluminum fuel line and the linkage is custom Dickster. I make my own, with Eelco parts of course. On the long throttle shafts simply make a collar with 2 set screws and a longer shaft the same size as the throttle shaft and attach so they are all out equally to the side.
  17. SinisterCustom
    SinisterCustom
    Nice setup.....
    On the throttle....I meant how are ya supporting the end of the extension, 'cause doesn't the extensions 'wiggle' up down/side & side to side some when throttle is applied???? And put excessive load/wear on the carb throttle shafts with the extensions??? At least that's what I've 'heard'.....
    I'm thinkin' a brace with 4 holes that slid over all four throttle shafts....to keep it all smooth and in tune.....
    I drive my PU ALOT, and if the long throttleshafts "walk around", even a little bit, it'll be constant tuning.....and frustrating.....I don't want to have to carry my Uni-Synch in my truck....hahahaha!!!!
  18. dickster27
    dickster27
    from Texas
    Josh, you have the right idea, you can simply make a plate support bar out of aluminum so as not to have any weight but I think it don't look for shit and I just make sure the right had carbs are tight enough not to wiggle. You gottsa remember that your linkage offers somewhat of support. Haven't had any problems as yet. But, there is always a first time.
  19. nailheadroadster
    nailheadroadster
    Hey Josh, You ever gonna get that POS intake on yer truck? GEEZ :) Dave
  20. SinisterCustom
    SinisterCustom
    FU Dave!!!! Hahahahaha!!! Trying to round up all the $tuff to get it going has taken time.....family takes priority...BUT, I hope to have it installed by month's end......*fingerscrossed
    I'll send ya pics!!!
