5-6-7 Chev door interchange??
Discussion in 'The Hokey Ass Message Board' started by Duke, Jun 1, 2008.
  1. Duke
    Duke
    I am picking up a 55 two door post and it has no doors. Will 56 and 57 doors work? What other body parts are interchangeable? Inner fenders? Trunk lids?
    Thanks
  2. Crestliner
    Crestliner
    Doors are the same, trunk lids will interchange.
  3. arkiehotrods
    arkiehotrods
    Doors are Hollander Interchange 805: Chevy 55-57 2 dr sedan, club cpe, Handyman S.W. and Sedan Delivery, Pontiac 55-57 2 dr sedan, Chieftain 2 dr S.W.
    Deck lids, Chevy 55-57, and 55 Pontiac Chieftain by changing locks
  4. hot_rod_17
    hot_rod_17
    I'm not 100% sure, but I think 5-6 inner fenders are the same.
  5. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Yep, pretty sure 55/56 inner fenders and radiator supports are same, 57 different. 56 front clip will fit a 55. In fact I've seen a couple of 55 Chevy's with 55 Pontiac front clips; Pontiac coming/Chevy going double-take! Gl*** interchanges year to year for the most part as long as it's the same body style (sedan,etc.).
  6. Duke
    Duke
    Thanks guys!!
  7. Torkwrench
    Torkwrench
    The doors all interchange,but 56's may have the door lock holes may be drilled a little lower than 55's & 57's, (not sure on this). I've been told this was to clear the 56 side trim. The front inner fenders are specific to each year. They all differ around the grill opening area. The radiator supports should all be the same, at least the U shaped part. These are specific for 6 cylinders and V8's though. The tie bar part of the radiator support is different for each year though.
  8. low budget
    low budget
    from Central Ky
    inner fenders and rad. supports are not the same in any of the years and pontiac fenders,hood etc. are longer in the front and will not work as they are longer wheelbase and thats where the diffrence in length is, unless it is a canadian built pontiac and they are the same as chevy
  9. belair
    belair
    Torkwrench is right about the lock location holes. Also, (obviously), holes for the stainless will be in different places.
  10. Duke
    Duke
    Does the front and rear gl*** from a 4 door work on a 2 door sedan?
  11. Squablow
    Squablow
    Yup, windshield and rear window from a 4 door sedan will fit into a 2 door sedan. 4 door hardtop gl*** (no post) is different.
    I didn't know that about the '56 door lock position. One of the doors I have for my '57 is from a '56 210 Handyman, now I'm going to have to measure that out.
  12. Duke
    Duke
    Do the Pontiacs also use the same window moldings (inside)?
    Thanks
  13. Upper and sides of front and rear windows will be the same, side window moldings the same, lower front across dash top may differ.
  14. jonzcustomshop
    jonzcustomshop
    the 56 belair has the different lock position, to account for the 2 strips of chrome.
  15. buckeye_01
    buckeye_01
    55 and 57 doors will interchange, but the locks on the 56 are higher.
