1952-59 Ford 5 Blade Fan for a 55
Discussion in 'Off Topic Hot Rods & Customs' started by Mr. Tomato Head, Aug 9, 2016.
Tags:
  1. Mr. Tomato Head
    Mr. Tomato Head
    I recently saw an after-market vintage Ford parts company offering a 5-blade replacement fan for 55 Fords. (as opposed to the factory 3-blade). Does anybody have first-hand experience with one? Worth it?
    Doesn't look too hard to swap out. (Pull radiator, I ***ume.) Mato
  2. Paul2748
    Paul2748
    A lot of the early TBird guys go with a 5 or 6 blade fan and it can help. Another thing that will help is a full shroud.
  3. Mr. Tomato Head
    Mr. Tomato Head
    Do you have a source for 55 specific shrouds?
  4. Paul2748
    Paul2748
    You might try Walker radiator in Tennessee. Not 55 specific, but they had different sizes that may work.
  5. HOTRODPRIMER
    HOTRODPRIMER
    I like this aftermarket fan from Summit,I have it on two of my cars. HRP
  6. Hunter73
    Hunter73
    Wow, I bet that does a great job!
  7. HOTRODPRIMER
    HOTRODPRIMER
    You bet,my cars never run hot. HRP
  8. Zapato
    Zapato
    I always look for 7 blade clutch mopar fans at the pull it yards usually require a very little to adapt. Measure first to be sure you have enough clearance. Can't be best if it'll fit. Also found on cherokees.
  9. Mr. Tomato Head
    Mr. Tomato Head
    I took another look at my (3-blade) fan to check clearance width for the addition of a shroud. It appears that the tips of the blades extend almost to the edge of the radiator itself. Does not appear to have room for a shroud based on how they're mounted. (Wire ties through the radiator?)
    Maybe I'm missing something. A shroud would be an easier fix. Mato
  10. JeffB2
    JeffB2
    from Phoenix,AZ
    Over the years when doing swaps we found early Mustang radiators to be a bolt-in swap in 1949-56 cars there are two sizes so check the measurements in this listing : http://www.ebay.com/itm/1967-1969-F...ash=item56880125ef:g:OGkAAMXQUmFSoN5p&vxp=mtr
  11. Mr. Tomato Head
    Mr. Tomato Head
    Did you mean , "we found early Mustang SHROUDS to be a bolt-in swap"? I need to check measurements for mounting slots on the Ebay link one. Other than that, dimensions looked pretty good. M
  12. JeffB2
    JeffB2
    from Phoenix,AZ
    The shrouds line up with the radiator mounting holes so it's a good fit as I remember a few said they elongated the holes slightly.
