Technical 5 on 4 1/2 drums on f100 spindles
Discussion in 'Traditional Hot Rods' started by rocketsled59, Aug 25, 2025.
  1. rocketsled59
    rocketsled59
    Anyone know what 5 on 4 1/2” drums can be fitted to 57-64 or 53-56 f100 spindles? Have a 62 f100 axle under my 56 Fairlane. Want to run 4 1/2” bp skinnys
  2. deathrowdave
    deathrowdave
    from NKy
    Thinkin a dividing head is your best answer
  3. alchemy
    alchemy
    Yes, way simpler to just redrill the hubs and press in fresh studs.
  4. 325w
    325w
    Drilled the hubs and drums on my 53-56 brakes. Better check the hole in the wheels before you spend money. The hub is over size by at least an 1/8
    jimmy six and bchctybob like this.
  5. rocketsled59
    rocketsled59
    Thanks for the reply’s. I drilled my hubs with an adapter as a guide. Bolts on to 5 1/2. Knocked studs out and transfer punched through holes for 4 1/2. It worked but not as accurate as I’d hoped. Seems ok with a conical seat lug nut but it’s not as forgiving with a shank style nut
  6. alchemy
    alchemy
    Yeah, that’s not how it’s done. You need to clamp to a mill and index off the center, then bore each hole from precise measurements. Even the most perfect “adapter” is gonna give a few thousandths of wiggle when you stick a drill bit through it. If those bad holes all tolerance to opposite sides, you might never get a wheel on, let alone drive without the shakes.
    Rotate the hub and try it the right way.
  7. ramblin dan
    ramblin dan
  8. gimpyshotrods
    gimpyshotrods
    This needs to be done in a machine shop, or by a qualified machinist, at least.
    I do this exact procedure a few times a month for customers. Any machine shop that remains open in this economy can do it too.
    They can also turn down the register on the hub to fit the wheel center hole, if that's an issue.
    There is no hope for accuracy without the proper tools and tooling.
    This is not even expensive.
  9. ramblin dan
    ramblin dan
    Seems to me I bought a set of hubs years ago from a place called Thompson's Garage that were for early Ford that had a 4 1/2 ford pattern instead of 5 1/2. There was also a template that I saw on Ebay. Sort of a jig to redrill your bolt pattern. $T2eC16dHJIIE9qTYLh3WBQSWDvCCLQ~~60_57.jpg $T2eC16JHJGkE9no8gIpmBQSWDuHsHw~~60_57.jpg $T2eC16VHJF0E9nmFRpH,BQSWD0Cz!!~~60_57.jpg
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    So what drums was the question?
    gimpyshotrods likes this.
  11. gimpyshotrods
    gimpyshotrods
    Stock drums, also re-drilled.
