5 Speed Transmission Info
Discussion in 'The Hokey Ass Message Board' started by Veach, Aug 13, 2013.
  1. Veach
    Veach
    Im putting a 5sd in my Falcon and this is what i found out Thanks to Car Craft ::You can get a new T5 from Jegs for under 1,600 :::Go to Car-craft for a complete rebuild of these transmissions :::::T5 Transmission - Pull-it-yourself Ford five-speeds
    Check out the tons of options for the pull-it-yourself Ford five-speeds
    The T5 is a great street transmission for small-block Fords as long as you don't treat it
    This is the era of the manual transmission. Sure, automatics are easy and comfortable, but there's nothing like rowing through a sweet five-speed and listening to a motor sing through the gears. For the Ford clan, the T5 has become the attractive, lightweight overdrive trans of choice. Ford has been building World Cl*** transmissions by the thousands since 1985, so we thought we'd take a close look at the choices for rebuilding or buying Ford-based five-speed transmissions.
    If you're not already aware, there's a whole industry built around this stout little transmission. The T5 is not for everyone, and it's certainly not suited for either big-block or nitrous use, but there are all kinds of uses not only for the T5, but also for its aftermarket performance derivatives like the Tremec 3550/TKO five-speeds that have now become the latest-generation Tremec TKO 500 and 600 boxes.
    For this story, we took apart a basic 3.35 First gear T5 and went through it to show you some of the highlights of ***embling a T5 with an all-new ge****t from our pals at D&D Performance. If you're in the market for a five-speed, we've done much of the research for you.
    If you want a good swap trans, look for a '90-or-later Mustang with a T5 in the boneyard,
    History of the T5
    While the '83 5.0 Mustang is where performance enthusiasts were first introduced to the T5, its lineage can be traced all the way back to the '81 AMC Spirit. The trans has been used in well over 200 applications and continues to appear in multiple production applications. The T5 can be split into two main categories: the early Non-World Cl*** (NWC), rated at 265 lb-ft of torque capacity, followed by the World Cl*** (WC) version beginning in 1985, rated at the same torque. The WC boxes are the only ones worthy of performance applications, but they still exhibit a couple of weak areas. We've outlined the gear ratios for all these boxes below. There are myriad T5 boxes used just within the Mustang world. D&D offers a chart on its Web site that identifies specific boxes along with their gear ratios and torque capacities.
    While the World Cl*** tag sounds impressive, the reality is that it wasn't until 1990, when Ford updated the T5 to 310 lb-ft of torque, that the transmissions could really be used in any kind of aggressive performance capacity. The latest version, the so-called "Z" box that was used in the '93 Cobra, is equipped with the best of all the updated parts including hardened gears, shortened shifter throws, a bearing collar made of steel, and tapered output-shaft bearings. The trans is available through many sources, such as D&D and Ford Racing.
    The Ratio GameThere are two categories of T5 transmissions used in the 5.0 Mustang, commonly differentiated by the First-gear ratio. There are also varying Third- and Fourth-gear ratios, depending on the year of the trans. This information comes courtesy of The Official Ford Mustang 5.0 Technical Reference & Performance Handbook by CC alum Al Kirschenbaum. It covers in excruciating detail all the tech information you'll need on 5.0 Mustangs. You can buy the book from Ford Racing or through Summit Racing.
    RATIOS
    1ST 2ND 3RD 4TH 5TH REVERSE
    '83-'84 2.95:1 1.94:1 1.34:1 1.00:1 0.72:1 2.76:1*
    '85-'89 3.35:1 1.93:1 1.29:1 1.00:1 0.68:1 3.15:1
    '89-on 3.35:1 1.99:1 1.33:1 1.00:1 0.68:1 3.15:1
    Tremec 500 3.27:1 1.98:1 1.34:1 1.00:1 0.68:1 3.01:1
    Tremec 600 2.87:1 1.89:1 1.28:1 1.00:1 0.64:1 2.56:1
    Tremec 600 2.87:1 1.89:1 1.28:1 1.00:1 0.82:1** 2.56:1
    *Ford also offered a 0.63:1 Overdrive ratio in 1983.
    **This trans is the road-race option where the rpm drop between Fourth and Fifth is much narrower.
    This is a '90 five-speed with a 3.35 First gear rebuilt with a stronger 2.95 ge****t.
    To determine any car's overall First-gear ratio, multiply the transmission's First-gear ratio by its rear-gear ratio. If your Mustang has a 3.35 First gear and a 3.55 rear gear, the overall First-gear ratio is 3.35 x 3.55 = 11.89. Anything greater than 9.5 could be considered overkill for the street. Ever driven a Mustang with a 3.35 First-gear trans and a 3.73 rear? First gear is virtually useless, since the overall ratio is 12.49. This is why a 2.95 First-gear T5 or the Tremec 600 2.87 trans is far more desirable if your plans include deep rear gears.
    To determine the Overdrive ratio, simply multiply the rear-gear ratio by the Overdrive. For a 3.73 rear gear and a 0.72 Overdrive, that's the equivalent of a 2.68 rear gear in Overdrive. If you're considering the Tremec 600 trans, a 3.73 with a 0.64 Fifth gear equals 2.39. This is a great way to lower the highway cruise rpm. Just remember, this combination will create high driveshaft speeds if you attempt to do a top-speed run; the driveshaft and the rear gears are spinning 36 percent faster than the engine!
    Trans Strength
    The strength of a manual transmission is related to four main design functions consisting of cluster-to-mainshaft center-to-center distance, First-gear ratio, gear-tooth pitch, and the alloy of the steel used to make the gears. The center-to-center distance is the dimension between the centerlines of the input shaft and cluster gear. A greater distance between these two gears increases gear diameter and strength. Note on the chart that the T5 has the shortest center distance while the much stronger T56 six-speed is more than 10 percent larger.
    First-gear ratio is determined by dividing the tooth count of the driven (cluster) gear by the tooth count of the drive (input) gear. As First gear becomes deeper (higher numerically, as in 3.35 versus 2.95), the input-shaft gear-tooth count becomes lower, making the gear smaller, while the cluster gear-tooth count and size become larger. In the case of our 3.35-geared T5, several input-shaft teeth broke, which destroyed both the input and the cluster.
    Tooth pitch is also a consideration. A straight cut or spur gear is the strongest but is also extremely noisy. As the pitch or angle of the gear tooth changes, it becomes quieter, but at the price of reduced strength. Another way to increase strength is to improve the quality of the steel used to make the gears. Since changing the center distance would require designing a new transmission, the T5's strength updates are limited to ratios and metallurgy improvements. Factory gears have evolved from 8620 to 4620 and 4615 alloys to improve strength. If you want serious strength, G-Force makes a helical-cut 2.94 low ge****t for the T5 out of 9310 nickel alloy with a 26-spline input shaft, but it's pricey.
    The bottom line on production-based T5s is that as long as you don't ham-fist the box with repeated power shifts, it will probably live a long and useful life. Abuse it, and count on becoming proficient at R&R-ing transmissions.
    The weak, 3.35 First-gear T5 we started with suffered an input-shaft-gear failure. While d
    A wider center distance between input-shaft (A) and cluster-shaft (B) centerlines improves
    Aftermarket five-speeds
    If you discover that rebuilding your existing T5 might not be cost-effective, an alternative could be the aftermarket derivatives of the T5. From the Ford camp, the strongest factory trans (rated at 330 lb-ft of torque capacity) is the "Z" trans (due to the letter Z found in the Ford part number) available from Ford Racing Performance Parts (FRPP) or D&D.
    In the aftermarket, Tremec first built the 3550 five-speed, which was later superseded by the TKO. Both the 3550 and now the TKO have been replaced by the TKO-500 and TKO-600. The numbers refer to their advertised torque capacities. The 600 uses a 2.87 First-gear ratio while the 500 employs a deeper 3.27 low gear.
    CENTER DISTANCES
    TRANSMISSION
    CAPACITY
    CENTER
    DISTANCE
    WEIGHT
    (POUNDS) TORQUE
    (LB-FT)
    T5 77 mm (3.03) 75 235-325
    Tremec TKO/3550 83 mm (3.26) 105 350-475
    Tremec 500/600 83 mm (3.26) 105 500-600
    T56 (six-speed) 85 mm (3.34) 115-129 330-550
    INPUT/OUTPUT SHAFTS
    INPUT
    (SPLINES) OUTPUT
    (SPLINES)
    T5 10 28
    Tremec 3550 10 28
    Tremec TKO 26 31
    Tremec 500/600 26 31
    The input shaft on '94-'95 T5s is 0.625 inch longer than earlier T5s.
    Rebuilding the T5
    We started out with a broken T5 purchased from a friend for $25. Then we contacted Don Walsh at D&D Performance to find out what we had. This is a case of doing it backward-we should have done our research first, but the price was right. "You have one of the ****py 3.35 boxes," Walsh told us. "The best way to go is to rebuild it with one of our 2.95 low ge****ts. Then you'd have a nice trans." That's what we did.
    The Tremec TK-500/600 can trace its roots all the way back to the Ford Top Loader four-spe
    What showed up a few days later was a 2.95 ge****t along with a complete rebuild kit that included all those tough-to-find small parts. We talked our pal and consummate car crafter Tim Moore at Moore Automotive into taking us through the rebuild. Manual transmissions are no picnic, and since we'd never done one before, it was an education. Other than a hydraulic press and some metric sockets, there aren't any specialty tools required, but this is much more of a job than we can show here in a step-by-step sequence. After watching Moore work, we can't recommend that a rookie attempt to rebuild this trans. If you'd rather purchase a professionally built version of this 2.95 box, D&D will sell you a rebuilt T5 with all the same parts for $999 plus the core.
    We'll show you some details and include a couple of things we learned along the way if you want to take a stab at rehashing your own T5. Our first recommendation is to go to Tremec's Web site and print out the free T5 rebuild manual. Tim used it to help him through the T5, although he did find a couple of areas that were a bit ambiguous. Here are a few of the major points.
    Remove the drift pin from the shifter, and pull the extension housing and top shift cover.
    The instructions say you can remove the entire cluster gear without pressing off the rear
    This is the new 2.95 ge****t from D&D. It includes a new cluster and input shaft; new Firs
    The rebuild kit includes all new bearings and synchros plus a pile of all the little parts
    At one obscure point, the Overdrive gear (arrow 1) is splined tightly on the mainshaft and
    Install the extension housing then check the endplay with a dial indicator on the output s
    Boneyard Warning
    The T5 used in the 5.0L Mustangs is very similar externally to T5s used in numerous other rear-wheel-drive applications-mostly in turbocharged SVO and nonturbo'd, four-cylinder Mustangs; the '89-'93 T-bird SC; 305ci Camaros and Firebirds; S-series pickups; and the '84 Nissan 300 ZX to name a few. These boxes all used different, and mostly weaker, First-gear ratios, with one as deep as 4.05. The one exception is the 305 Camaro/Firebird 2.95 WC First-gear boxes from '88-'92. According to D&D, these boxes are basically as strong as the comparable WC Ford 5.0 transmissions. Do not be fooled into thinking you can adapt the other T5s into a high-output, V-8 application. We don't need to tell you the Nissan boxes do not interchange with the Ford units, do we?
    VARIOUS PARTS
    DESCRIPTION PN SOURCE PRICE
    2.95 ge****t AK2 D&D Performance $449.00
    T5 rebuild kit AK3 D&D Performance 189.00
    Steel brg. retainer '85-'93 AC3 D&D Performance 49.00
    Steel brg. retainer '94-up AC34 D&D Performance 49.00
    302/351 to T5 bellhousing C108 D&D Performance 179.00
    302/351 to 3500 bellhousing C14 D&D Performance 169.00
    302/351 steel bellhousing C15 D&D Performance 299.00
    Steel slip-yoke for T5 D32 D&D Performance 79.00
    2.94 9310 ge****t for T5 Call G-Force Transmissions 1,095.00
    Mainshaft, 4340 steel GFT5022-1 G-Force Transmissions 565.00
    Rebuilt T5, 330 lb-ft cap. AA251 D&D Performance 999.00
    T5 Cobra R "Z" M-7003-R58 D&D Performance Call
    T5 Super Duty M-7003-Z D&D Performance Call
    Tremec 600, 2.87 First TA-600F D&D Performance Call
    Tremec 500, 3.27 First TA-500F D&D Performance Call
    Mustang 5.0 reference book M-1832-Z4 Summit Racing 27.88
    SOURCES
    150 N. Grant St.
    Cleona
    PA 17042 TREMEC
    23382 Commerce Dr.
    Farmington Hills
    MI 48335
    Powerbuilt Tools/Alltrade
    Long Beach
    CA
    alltradetools.com D&D Performance
    6632 Telegraph Rd.
    Bloomfield Hills
    MI 48301
    8-10/-647-3179
    Summit Racing
    P.O. Box 909
    Akron
    OH 44309-0909
    800-230-3030
    www.summitracing.com Moore Automotive
    Sun Valley
    CA 91352
    Read more: http://www.carcraft.com/howto/116_0609_t5_transmission/viewall.html#ixzz2boxnkOAo
  2. Flat Ernie
    Flat Ernie
    Tech Editor
    Is there a question in there somewhere?
  3. blowby
    blowby
    from Nicasio Ca
    End of last paragraph.
  4. 73RR
    73RR
    ...apparently a writer for CC...
  5. dirty old man
    dirty old man
    Well whoever he is, there's a lot of tech info in those words. Only thing I know about the T5 is that I had an OT '79 Mustang I used as a DD on a 35 miles each way commute for years and I put a T5 from an '84 in it when the OEM alum case 4 speed with 4th OD wore out, and had I known how much better it would perform, especially on ratio spread, I'd have done it years before. As I said, commuter car with stock 2bbl 302.
    Fellow Sock ****er Dogpatch has had all sorts of problems as relates to high rpm shifts on the later T56s and so on in his "A" both with the Desoto hemi and the 392 now in it.
  6. Jay Tyrrell
    Jay Tyrrell
    Thanks for sharing man!
    Jay
  7. blowby
    blowby
    from Nicasio Ca
    Somebody was telling me the other day to put 90w in my T5 that originally had ATF (or something red) in it. Br*** synchros. He said they went to ATF so the cars would shift easier when new or something like that. Sounded fishy to me.
  8. Jay Tyrrell
    Jay Tyrrell
    I have heard that too for the T5s... I know for the Tremecs that you put in synchromesh fluid (spelling?) The fluid info for the T5 transmission would be helpful because I am about a month away from filling up a T5 in a project that I have been working on.
    Jay
  9. ago
    ago
    from pgh. pa.
    I believe the non world cl*** T5 has br*** synchros and uses 90W, the world cl*** T5 has composite synchros so it needs ATF. The Tremec TKO requires
    Synchromesh fluid. Don't mix it up.
    Ago
  10. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The WC T-5s I've seen had a sticker on the p***enger side stating that they should have ATF.
  11. Hnstray
    Hnstray
    from Quincy, IL
    When using Gear Lube....90W....anything with br*** in it needs GL-4.......NOT GL-5...
    additives in GL-5 are chemically incompatible with br*** and damage those parts.
    GL-4 is getting harder to find at the friendly local auto parts stores, tractor supply, etc. at least in part of the world, but is available from on-line sources.
    And, I do believe, T-5 uses ATF or "syncromesh" fluid, not gear oil.
    Ray
  12. Truckedup
    Truckedup
    I have a 1984 GM service manual supplement for the NWC T-5 and it says ATF. Some guys like the light gear oils,Synchromesh Fluid or the Redline gear oil version of the same.
    I'm a bit surprised the early NWC S10 T-5's can hold up behind a V-8. It was not much problem to break one with the gutless S10 2.8 engine...
  13. Veach
    Veach
    No question I am trying to find the right 5sd for my Wagon and found this info and figured I'm not the only person doing so and thought it might help someone else that's the reason for this Sight Right ?
  14. Saxman
    Saxman
    This is great info. Thanks for sharing.
  15. gimpyshotrods
    gimpyshotrods
    I am still running a six, but I have an S10 T5 behind it, in my '60 Falcon. It works very well.
  16. Veach
    Veach
    A lot of people are running the 5sd that is why I posted this and I know now that my first gear won't be doing much with a 389 gear unless I can find the right one
  17. gimpyshotrods
    gimpyshotrods
    Do you have a 6 or an V8?
  18. Veach
    Veach
    It's a 60 Wagon with a 347V8, right now She has a 4sd but I'm looking for a 5sd and She has a Currie 9" 389 Trutrack
  19. gimpyshotrods
    gimpyshotrods
    Mid-late 80's Mustang T5 should fit that bill. The tunnel is super-tight, so an S10 tailhousing is in order. The first gear is not that low. What is the height of your rear tires?
  20. Veach
    Veach
    P215/70R15 on the front Tread 6' Diameter 26.9 Wheel 15x7 :::: P245/60R15 on the rear Tread 8" Diameter 26.6 Wheel 15x8 ::When I was building Her I made some room for a larger Transmission
    But She is tight in the rear for now but thinking of a tub I have already moved the torque boxes to the inside of the frame with the bottom two links and removed the springs for coil overs And Thanks for your Help ::: BTW I Love your 29 lots of fab work mine also had a lot and I would love to see that 60 Falcon
  21. gimpyshotrods
    gimpyshotrods
    <table frame="VOID" cols="12" rules="NONE" border="0" cellspacing="0"><colgroup><col width="100"><col width="86"><col width="119"><col width="119"><col width="86"><col width="86"><col width="86"><col width="86"><col width="86"><col width="86"><col width="86"><col width="86"> </colgroup><tbody><tr><td height="17" align="LEFT" width="100">Mustang T5</td><td align="LEFT" width="86">RPM</td><td align="RIGHT" width="119">1000.00</td><td align="RIGHT" width="119">1500.00</td><td align="RIGHT" width="86">2000.00</td><td align="RIGHT" width="86">2500.00</td><td align="RIGHT" width="86">3000.00</td><td align="RIGHT" width="86">3500.00</td><td align="RIGHT" width="86">4000.00</td><td align="RIGHT" width="86">4500.00</td><td align="RIGHT" width="86">5000.00</td><td align="LEFT" width="86">
    </td></tr><tr><td height="17" align="LEFT">
    </td><td align="RIGHT">3.35</td><td align="RIGHT">6.07</td><td align="RIGHT">9.11</td><td align="RIGHT">12.15</td><td align="RIGHT">9.11</td><td align="RIGHT">12.15</td><td align="RIGHT">21.25</td><td align="RIGHT">24.29</td><td align="RIGHT">27.33</td><td align="RIGHT">30.36</td><td align="LEFT">
    </td></tr><tr><td height="17" align="LEFT">3.89:1 Rear gear.</td><td align="RIGHT">1.93</td><td align="RIGHT">10.54</td><td align="RIGHT">15.81</td><td align="RIGHT">21.08</td><td align="RIGHT">15.81</td><td align="RIGHT">21.08</td><td align="RIGHT">36.89</td><td align="RIGHT">42.16</td><td align="RIGHT">47.43</td><td align="RIGHT">52.70</td><td align="LEFT">
    </td></tr><tr><td height="17" align="LEFT">26.6” Rear tire.</td><td align="RIGHT">1.29</td><td align="RIGHT">15.77</td><td align="RIGHT">23.65</td><td align="RIGHT">31.54</td><td align="RIGHT">23.65</td><td align="RIGHT">31.54</td><td align="RIGHT">55.19</td><td align="RIGHT">63.08</td><td align="RIGHT">70.96</td><td align="RIGHT">78.85</td><td align="LEFT">
    </td></tr><tr><td height="18" align="LEFT">
    </td><td align="RIGHT">1.00</td><td align="RIGHT">20.34</td><td align="RIGHT">30.51</td><td align="RIGHT">40.69</td><td align="RIGHT">50.86</td><td align="RIGHT">61.03</td><td align="RIGHT">71.20</td><td align="RIGHT">81.37</td><td align="RIGHT">91.54</td><td align="RIGHT">101.72</td><td align="LEFT">
    </td><td align="RIGHT">0.68</td><td align="RIGHT">29.92</td><td align="RIGHT">44.87</td><td align="RIGHT">59.83</td><td align="RIGHT">74.79</td><td align="RIGHT">89.75</td><td align="RIGHT">104.71</td><td align="RIGHT">119.67</td><td align="RIGHT">134.62</td><td align="RIGHT">149.58</td><td align="LEFT">
    </td></tr></tbody> </table>
  22. Veach
    Veach
    I can't tell you how much I Thank You for the info if I can be of help to you Please ask
  23. gimpyshotrods
    gimpyshotrods
  24. gimpyshotrods
    gimpyshotrods
    <table frame="VOID" cols="11" rules="NONE" border="0" cellspacing="0"><colgroup><col width="100"><col width="86"><col width="119"><col width="119"><col width="86"><col width="86"><col width="86"><col width="86"><col width="86"><col width="86"><col width="86"> </colgroup><tbody><tr><td height="17" align="LEFT" width="100">Mustang T5</td><td align="LEFT" width="86">RPM</td><td align="RIGHT" width="119">1000.00</td><td align="RIGHT" width="119">1500.00</td><td align="RIGHT" width="86">2000.00</td><td align="RIGHT" width="86">2500.00</td><td align="RIGHT" width="86">3000.00</td><td align="RIGHT" width="86">3500.00</td><td align="RIGHT" width="86">4000.00</td><td align="RIGHT" width="86">4500.00</td><td align="RIGHT" width="86">5000.00</td></tr><tr><td height="17" align="LEFT">
    </td><td align="RIGHT">2.95</td><td align="RIGHT">6.90</td><td align="RIGHT">10.34</td><td align="RIGHT">13.79</td><td align="RIGHT">10.34</td><td align="RIGHT">13.79</td><td align="RIGHT">24.14</td><td align="RIGHT">27.58</td><td align="RIGHT">31.03</td><td align="RIGHT">34.48</td></tr><tr><td height="17" align="LEFT">3.89:1 Rear gear.</td><td align="RIGHT">1.94</td><td align="RIGHT">10.49</td><td align="RIGHT">15.73</td><td align="RIGHT">20.97</td><td align="RIGHT">15.73</td><td align="RIGHT">20.97</td><td align="RIGHT">36.70</td><td align="RIGHT">41.94</td><td align="RIGHT">47.19</td><td align="RIGHT">52.43</td></tr><tr><td height="17" align="LEFT">26.6” Rear tire.</td><td align="RIGHT">1.34</td><td align="RIGHT">15.18</td><td align="RIGHT">22.77</td><td align="RIGHT">30.36</td><td align="RIGHT">22.77</td><td align="RIGHT">30.36</td><td align="RIGHT">53.14</td><td align="RIGHT">60.73</td><td align="RIGHT">68.32</td><td align="RIGHT">75.91</td></tr><tr><td height="18" align="LEFT">
    </td><td align="RIGHT">1.00</td><td align="RIGHT">20.34</td><td align="RIGHT">30.51</td><td align="RIGHT">40.69</td><td align="RIGHT">50.86</td><td align="RIGHT">61.03</td><td align="RIGHT">71.20</td><td align="RIGHT">81.37</td><td align="RIGHT">91.54</td><td align="RIGHT">101.72</td></tr><tr><td height="17" align="LEFT">
    </td><td align="RIGHT">0.72</td><td align="RIGHT">28.25</td><td align="RIGHT">42.38</td><td align="RIGHT">56.51</td><td align="RIGHT">70.64</td><td align="RIGHT">84.76</td><td align="RIGHT">98.89</td><td align="RIGHT">113.02</td><td align="RIGHT">127.14</td><td align="RIGHT">141.27</td></tr></tbody> </table>
  25. JEM
    JEM
    Amsoil has a GL4 gear oil that's worked really well for me. Local dealer wants an arm, a leg, and a testicle for it though.
  26. Veach
    Veach
    Maybe an arm and leg but I really need them testicles still would love to see that 60 Falcon gimpyshotrods :)
  27. gimpyshotrods
    gimpyshotrods
    All the work, so far, has been underneath. All of the suspension has been replaced/upgraded. The transmission and axle have been swapped out. It is now 2" lower than in this picture.
  28. Veach
    Veach
    I know what you mean about under Her She is already Very Nice but She will be Awesome.If you get a chance take a look under mine and tell me what you think
  29. Flat Ernie
    Flat Ernie
    Tech Editor
    The original T5 in early Fords was NWC and Ford specified a Ford P/N that translates to 70wt gear oil. In '85, Ford put the WC T5 in and changed the specification to ATF - including retroactively putting ATF into the NWC T5. I've always heard that was done for shift feel, but I can tell having driven a NWC with both, it's night and day.
    The T5 is a lot tougher than people give it credit for. So, here's what I do - I run synthetic ATF in all of my T5 no matter what make, model, or cl*** it is. BUT, I don't think it makes enough difference to matter, so if you're concerned about br*** synchros, run some GL4 (if you can find and pay for it), but keep the weight down to 70wt. If you prefer to run the GM Synchromesh (or other branded formulations), go right ahead. I've even heard of folks running 50wt motor oil (I wouldn't recommend that).
    At the end of the day, if you're putting power through a T5, you'd better be running a WC T5 and if you are, there is no question you should be running ATF. Pay the extra couple of dollars for the synthetic stuff. If you're not running power through a T5, run whatever you want in the ******...
    ymmv
  30. Veach
    Veach
    Turned out to be an excellent post because I have learned a lot Thank Y'all
