5 Speed Transmission Info
Discussion in 'The Hokey Ass Message Board' started by Veach, Aug 13, 2013.
  1. Veach
    Veach
    New question going with a newer 5sd Transmission the input shaft will not be a 10 spline so I have to change the flywheel and clutch so which one are you using or which one would you go with ?
  2. gimpyshotrods
    gimpyshotrods
    I am going to ***ume that the 347 is 302 based, which could be a 28-oz. or a 50-oz. balance flywheel. If it is late-style, it is probably a 10-1/2" clutch. In that case, pick your favorite, from the equivalent era Mustang. If it is based on an early style SBF, you may have to check the diameter, but again, once confirmed, any reputable supplier of clutches/discs should be good.
    My application isn't applicable here. I machined and tapped my stepped flywheel to accept a Mercedes pressure plate, and a Diesel Jeep disc.
    Oh and the whole flywheel tooth count/diameter/bellhousing/block plate/starter all matching thing, must be minded, too. Mix-and-match does not always work.
  3. Veach
    Veach
  4. blowby
    blowby
    from Nicasio Ca
    Ernie, just to be clear, you're saying the shifting was night and day better with the ATF?
    Thanks.
  5. 61falcon
    61falcon
    i have a t5 that i bought new from summit racing in my Falcon with a 331 stroked 5.0 with a 3.90 gear and have no issues with first gear being to steap.
  6. Veach
    Veach
  7. Flat Ernie
    Flat Ernie
    Tech Editor
    Yep. Much better with the ATF - smoother, quicker shifts.
