50/50 primer and paint ?
Discussion in 'The Hokey Ass Message Board' started by AD, Jan 26, 2009.
  1. AD
    AD
    i've read about it a couple times now. Anybody ever done this? I figure after bodywork and a good primer this finish will hold till i'm ready financially for some good paint, But if anybody's got input I'd like to hear it,,
  2. plodge55aqua
    plodge55aqua
    from Alberta
    Are you going to leave it sit? or drive it?
  3. AD
    AD
  4. AD
    AD
    on top i didn't make it too clear on what i was talking bout, i read where back in the day the dude made a mix of 50% primer w/ 50% base coat,, he went for a yellow , i wanna go w/ a coffee color,, idunno if it matters whether its dark or light paint
  5. plodge55aqua
    plodge55aqua
    from Alberta
    I think you can get tintable primer made up at a paint supplier.. close to the color you would like to apply to your vehicle.. they used the tintable primer to help with the low hiding colors that dont cover very well.. I know theres a few suppliers that carry that .. hope that helps..
  6. plodge55aqua
    plodge55aqua
    from Alberta
    I had a friend that did the same thing with his 50 merc.. . it seemed to work okay for a couple of summers.. just keep in mind.. its still primer, and it will absorb moisture..
  7. 49ratfink
    49ratfink
    wait til you are ready for the shiney stuff and do it all at once.
  8. AD
    AD
    ahhh yess moisture sucks, good point,, thanks,, tintable primer sounds good, thanks again
  9. Abomb
    Abomb
    If it were mine, I'd spend a little extra money and put a flattened single stage urethane on it. It would hold up to the elements, and seal what bodywork you've already completed.
  10. SwitchBlade327
    SwitchBlade327
    THIS.
    Primer will not seal out the elements for longs at all. I got guy to mix me up a semi-gloss metallic single stage for me to use as a temporary paint job after stripping my car. I don't have to worry about stripping it again because of rust starting under the primer now.
  11. olscrounger
    olscrounger
    In 1959 my Dad had some white primer tinted with Cat yellow and painted my 37 Ford PU--looked pretty cool and lasted for a couple of years--another guy in town did a similar purple tinted primer on a 50 Ford
  12. sik_kreations
    sik_kreations
    ya thats cuz it was lacquer. u can mix the lacquer like that.
    urethanes now, u cant, unless its a tintable version.
    the price u pay to get a tintable primer, u could ss the whole car with real paint.
    i hate the word temporary when it comes to painting a vehicle. its alot of work, wasted time, and money. to get rid of something u didnt really want in the first place.
    do it once, call it dun!
  13. SlowandLow63
    SlowandLow63
    from Central NJ
    Um hmm.
    The point of tintable primers is so you can closely match your basecoat to aid in coverage and get your color quicker in less coats. For instance, I just painted a '36 Dodge that used to be silver/black 2 tone. I sealed it all in black and then topcoated in black. That way I didn't have to try and cover the silver with the black topcoat. Dig?
    I think your trying to go for the "hot rod" look but not black. Use a flattened single stage as mentioned for this. Primer, tinted with basecoat or not, will allow moisture thorugh.
  14. oilslinger53
    oilslinger53
    from covina CA
    I'd wait til I had the paint. primer absorbs water like a sponge, and so does filler.
  15. cavistyle
    cavistyle
    from baltimore
    When i primed my cavalier i used U-POL color primer/sealer... It comes in white and has 10 color packs and a color chart for you to mix the color how u want.. held up well for about a year.. had some fadding tho but the car was never garage kept
