Hot Rods 50 chev panel straight axle lift
Discussion in 'The Hokey Ass Message Board' started by BiG DawG, Apr 25, 2014.
  1. BiG DawG
    BiG DawG
    I'm planning to do a lift on the front of my 50 chev panel (ambulance), a gasser look.
    Is there a "how to" on the H.A.M.B. that goes into the process? I've done a couple searches and haven't found anything yet.
    Thanks!
    BiG DawG
  2. squirrel
    First, is it a Panel Truck (truck based), or a Sedan Delivery (car based)?
  3. High5
    High5
    If you have an ambulance built from the car platform and just want the look of a gasser, an inexpensive route to go is through the use of riser blocks. There's a series of 16 3/8" diameter bolts that hold the front suspension crossmember to the frame. Unbolt those and either fabricate blocks to the desired height or purchase some I-Beam steel or tubing and slide it between the frame and crossmember. Here's some example's:
    If you decide to go a straight axle install, then this thread may help:
    http://www.jalopyjournal.com/forum/showthread.php?t=527419&highlight=51+chevy+gasser
