'50 chevy convertible questions
Discussion in 'The Hokey Ass Message Board' started by jonzcustomshop, Jun 10, 2009.
  1. jonzcustomshop
    jonzcustomshop
    I have a 50 chev convertible that has been on the back burner since '88 or so...
    I have finally decided that if I don't at least put it together and get it running I may never get a chance to drive it.
    So I am getting started..
    I have a 57 gmc straight 6 that will go in it.
    The rear has been changed, so it has an open driveline now, I think the rear in it now is a 56 chev.
    What kind of ****** can/should I run-one that I can hook up to the jimmy, and still fit within the X for the convertible frame?
    Is the 567 rear pretty much a direct bolt in on a 49-54 chev?
    it looks like it fits, but I stuck it i there 20 years ago just to roll it around..
  2. jonzcustomshop
    jonzcustomshop
    soooo.. anyone buildng a 49-54 convertible without the stock running gear?
    Any hints tips?
    I can't be the only one!
  3. 325w
    325w
    Using stock 567 you must drill new locating hole for the spring bolt pin.
  4. jonzcustomshop
    jonzcustomshop
    thanks! 325w I remember that now that you mention it.
  5. jonzcustomshop
    jonzcustomshop
    I wonder,,,,,,, If I should just put an S10 frame under it,,,,,???
  6. Chaz
    Chaz
    Jeez Jon, I hope that was a joke.... I've seen that car. Its a cool old custom...You should just bring it back to its 50's /60's show condition IMHO
  7. jonzcustomshop
    jonzcustomshop
    haha I'm just trying to get some kind of f*cking response!!
    You would think that with all the hambers on here with 49-54 chevs that someone had built one with an open driveline!!!
    and maybe one of them did it with a convertible,,,,,,
    yes it is going back to its 50's-60's configuration, for now its keeping the original paint job too, the only things that were missing from the original car were the skirts, and hood.
    I'll try to find some pics of it, maybe that will stir up some interest,,,,,
  8. 53olds
    53olds
    exactly what custom is this????? not this one is it?
  9. 49ratfink
    49ratfink
    well if you are running a GMC six I would figure get a GM 3 speed. maybe a later one with full synchros. not sure about what modifications that X member would need for a bigger trans. I've seen those frames but didn't pay too much attention to how things went together. one thing for sure... a later automatic will be way bigger than the 3 speed
    regardless there is nothing that can't be re-enginneered with the help of a sawzalll and a welder.
  10. jonzcustomshop
    jonzcustomshop
    It was proably cloned of of that one in the early 60's,pretty much the same, not chopped.
  11. 53olds
    53olds
  12. rdstr31
    rdstr31
    from Ney, OH
    Go here:
    http://www.chevytalk.org/fusionbb/showforum.php?fid/30/fp/1/
    You'll find everything you need.
  13. jonzcustomshop
    jonzcustomshop
    That will help.
    thanks!
  14. 53olds
    53olds
  15. jonzcustomshop
    jonzcustomshop
    77.jpg 55.jpg 88.jpg 66.jpg 44.jpg 33.jpg 22.jpg Ok here's the pics, they were in an album dated 1985, so I guess it was 24 years ago!
    we cleaned it up, and then pretty much just stuck it in a storage shed for 2 decades...
    check out the bantha tracks shirt in the 4th pic!
    the last couple pics was me experimenting with some 54 chev, and olds grille pieces...
    lewk likes this.
  16. hotrodladycrusr
    hotrodladycrusr
    The heart on the back seat cracks me up.:D
  17. Chaz
    Chaz
    I want that car!
  18. jonzcustomshop
    jonzcustomshop
    If you look close there are some on the front too!lol
    Not sure if I am keeping those....
    I probably will go the way I found it with the grille for now,I might throw some 54 teeth in there, I really like the look of this one:
  19. vetmansteve
    vetmansteve
    from texas
    I read that you have a '50 Chevy conv. that you are starting to restore. I have a '50 Chevy hardtop that I am converting to a conv. I have everything to make the swap, but I need some pictures of how the folding frame attaches to the body, and how it folds into the space behind the rear seat. Any pictures would be appreciated. I plan to use a small block chevy engine, and a 700 R4 trans. Haven't decided on the rear end. Thanks, Steve.
    contact me at vetmansteve@aol.com.
  20. The rearend you have will be a good choice. I put a later model rearend in a 50 or 51 Chevy sedan, I flipped the rear springs around, front to back. The rearend lined up great. I also used an S10 5spd ****** behind the 57 straight 6. Dean
  21. beaker bestley
    beaker bestley
    from utah
    hey friend just starting a 50 chevy convert any advice would be great. also i need a few parts if you no whare to look thanks
  22. thewishartkid
    thewishartkid
    I remember when you put some of the photos a few years earlier, I remember I thought the headlight and taillight treatment was neat. I have a 50 Hardtop. I want to do the 55 chevy headlight treatment on mine.
  23. todztoyz
    todztoyz
    I've got the same feeling about mine. Too many projects right now, but hopefully its next. I'd look at a camaro/fireturd 5 spd. Good luck, keep us posted!
