50 Chevy taillight treatment, custom guys apply within
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Feb 15, 2004.
  1. Roothawg
    Roothawg
    Well I got the hole cut now it's time to deide on the angle.
    I'll just show you what I have done thus far.
    I just have the frenching bucket sitting in the hole I can move it forward or aft depending on what looks right. Should I build up the sheetmetal around it or just cut her off and make it flush.
    Here is a pic or 2....
  2. Roothawg
    Roothawg
  3. Roothawg
    Roothawg
  4. Roothawg
    Roothawg
    Here it is before....the other side but you get the idea.
  5. SwitchBlade327
    SwitchBlade327
    I'm not real sure on how it would look with the metal built up around it. I'm more inclined to say to put them in flush, maybe sank in just a little...maybe some photoshop people can help...I"m having a hard time visualizing right now...
  6. Roothawg
    Roothawg
    Here's the filler plate for the old light.
  7. Roothawg
    Roothawg
    These are not my first choice but I can't wait around on a set of Kaiser tailights. They are a lot of dough and I hafta get this project rolling. So I will make do with what I have. The Fleetline has a lot of compound curves so it make it very difficult to locate anything that looks "straight".
  8. kustombuilder
    kustombuilder
    from Novi, MI
    i'd sink em in a bit and trim em to fit the stock quarter. if you try to build metal out to it they will look stuck on and out of place. kinda like a pimple.
  9. Roothawg
    Roothawg
    That's the way I am leaning but I always want HAMB backup...it's the American way. [​IMG]
  10. SwitchBlade327
    SwitchBlade327
    at least kustombuilder could actually say what I had going on in my head....it ain't been my day for speaking...
  11. Ron
    Ron
    I agree with SB and KB you don't want them to stick out any at all. Keep pretty much the same orig body shape from the side.
  12. Roothawg
    Roothawg
    About how deep ya'll reckon I oughta sink em?
    Until I get a 90 degree on the back wall of the bucket?
  13. kustombuilder
    kustombuilder
    from Novi, MI
    play around with it, stick the lense in and see where you like it best. then weld it there.
  14. Roothawg
    Roothawg
    Just wondering on the angle of the lens. I didn't want the lens at the same angle as the body line or it would be sticking up towards the sky...know what I mean Vern?
  15. kustombuilder
    kustombuilder
    from Novi, MI
    YUP! i find it best to just move it around at this point, till it's where you like it. make sure to do it WITH the lense in so you get a more accurate feel for what it'll look like done.
  16. kustomd
    kustomd
    I would just set them in maybe about 3/4" deep from the highest point on the fender. Does that make any sense? to bad you already started on it cause I would like to see a fastback with the 49 ford taillights setup like Mcphails 52 I haven't seen one that I know of and I think it would look pretty kickass with the top of the car sloping back on a fastback like they do. Just my opinion tho. I couldn't tell from the size of the buckets what lights you were using you may already be using ford taillights.
  17. Roothawg
    Roothawg
    Thanks...I have to score some lens for it now. I have the buckets and housings but no lens or bezels.
  18. Ron
    Ron
    [ QUOTE ]
    [/ QUOTE ]
    Gene Winfield's lenses look the best. The price is not bad either.
  19. Roothawg
    Roothawg
    Tell me more...I have been surfing on the web for a while. I need the bezels too.
  20. DrJ
    DrJ
    I would set them dead nuts verticle, but only after sitting the car on stands to ensure it is totlally level first. In otherwords make the tail light housings perpendicular to the running boards.
    They need to be on the same angle as each other and not cocked sideways either as looking from the rear or from above. You can probably rig up a temporary jig to line them up square with each other using a drilled piece of angle iron inside the trunk going from side to side. I would hammer a roll into the edge of the opening about the same radius as the window opening curve rather than just weld them in square cornered. It's a bit of nit picky work but it'd be worth it.
    Also if you roll the bottom edge in more then you can sink the whole assembly more before you run out of tunnel at the top.
    You probably don't want to put the '54 Chevy peak at the top but if the rolled edge and the tunnel start running out of metal to blend together you might be able to work in a stubby version of one o' them license plate dildos at the top making it have an "organic" look... Hell, it'd look like a clit, and there ain't nuthin wrong with that look.! [​IMG]
  21. Ron
    Ron
    Gene makes lenses for 49/50 Fords, 54 Chevy, and some others. His are two parts the red outer lens is smooth, the inner clear lens has the texture/prism to it. Most of the Lee style lenses are just one piece smooth on the outside with texture/prism on the inside. So when the form them the outside gets a textured or waffle look look to them. So Gene's just have a much smoother look to them. Besides Gene is a hell of a nice guy.
    I think Nightprowlers sells the repop bezels.
    I think this is right if I can look later or someone may know for sure.
    Winfield Rod and Custom
    8201 Sierra Hwy.
    Mojave, CA 93050.
    Phone: 661-824-4728
  22. Roothawg
    Roothawg
    Thanks ...I'll try and call him this afternoon.
  23. Rocket88
    Rocket88
    Flush with the body! They look way smoother that way.
    I'd show you a pic of how my bro did his, the StarPhoto has been brutally slow as of late. [​IMG]
  24. wayfarer
    wayfarer
    Moon sells reproduction bezels. When I put the frenched buckets in the dodge, I put them in, moved back and looked at it from where someone following the car would. I moved them until they looked the way I wanted them, then welded the bucket to the rear at the depth I wanted and finally cut off the extra depth of the bucket.
  25. Roothawg
    Roothawg
    Here's an email from Gary at Night Prowlers about the lens and bezels, for those who were wondering.
    Chris:
    We have new glass taillight lens for the '49 - '50 Ford. A plain glass lens is $10.00. A glass lens with a glass blue dot installed is $16.00 each. We also have a custom, acrylic, bubble lens for $45.00 for a pair. We have new, chrome taillight bezels for $20.00 each.
    We hope we can serve you in the future!
    Gary
    Night Prowlers
  26. Rocket88
    Rocket88
    Ok, StarPhoto seems to be workin again.
    Here's the tail of my bro's 50.
    He used 48 Ford tail lights.
  27. Sailor
    Sailor
    I think they would look best flush, so that nothing sticks out and disturbs the profile and at the same time avoid too much tunneling (never felt quite comfortable with the look of that).
    I know its late, but if I had a Fleetline, I would have the taillights in the bumberguards and leave the bodywork totally smooth.
  28. Ron
    Ron
    [ QUOTE ]
    [/ QUOTE ]
    Winfield's still look best;) Lens that is.
    [ QUOTE ]
    [/ QUOTE ]
    Me too.
  29. Roothawg
    Roothawg
    I frenched the first one. It looks ok, not sure if I like it or not. Too late now... [​IMG] Not bad for my first custom...some may argue that though.
    I thought about having the taillights in the bumper guards but I was afraid it would be too far down out of SUV line of sight.....I'll post pics later.
  30. JimC
    JimC
    from W.C.,Mo.
    Roothawg, that is a good point.
    I have seen lights in the bumpers, various locations, and above the bumper in the panel below the trunk.
    I do not think you can find a location that is "safe" because folks just do not pay attention.
    I read RF's editorial in the new CR and it is along the lines that people can be distracted while driving.
    Back to the tail lights, the newer cars have large, brilliant lights, and people miss them.
    Bottom line, put the lights where they are pleasing to you. After all, your car has only to plese one person.
    Jim
