Technical '50 Ford Rear Door Adjustment
Discussion in 'Traditional Hot Rods' started by Michael Savela, Apr 6, 2020.
  1. Michael Savela
    Michael Savela
    So I've had my '50 for about a year now. Woken up from her 30+ year nap. Running, lights work, hell I even got the radio working. But now onto the cosmetics. The driver side rear door sits proud by about 1/4" when latched at the latch, not the hinge side. I believe the catch can be adjusted in and out by loosening the 2 big phillips head screws that hold it on? If so, what size is the head, way larger than a #2 and I don't want to strip the heads so if someone can point me to a source for the right head size and adjustment procedure, it'd be helpful.
    Mike
  2. Slopok
    Slopok
    Don't know about the size but an impact driver will be necessary to break them loose.
    RMONTY and dwollam like this.
  3. dwollam
    dwollam
    What @Slopok said! Big phillips bit in impact driver.
    Dave
  4. s55mercury66
    s55mercury66
    from SW Wyoming
    #3 or 4 Phillips, an impact driver is definitely the way to loosen them, but I like to use a wrench on the hex on my screwdriver when I tighten them up. It will get them tight enough, and they get enough of a beating getting them loose. Inspect and lube all of the latches and stuff, along with the hinges on a yearly basis, and you will save yourself a lot of wear and headaches also. Same thing applies to the hood and the trunk, maintenance be always cheaper than repair.
