50 Ford Rearend Change To 8 Inch
Discussion in 'The Hokey Ass Message Board' started by AWSOME 50, Dec 20, 2006.
  1. AWSOME 50
    AWSOME 50
    from buffalo ny
    I Have Been Told That A Maverick 8" Rear Is A Direct Bolt In For The 50 Ford Coupe,i Am Wondering If A Ranger Rear Would Do The Same And Give Me The Same Clearence I Am Open To Other Suggestions Also Thanks. John
  2. extremist
    extremist
    The 8" is the right width. 57-59 9" fit. There are some 8.8" that are close enough to work with some slight tweaks.
    Do a search... there are a billion posts here on this topic.
  3. Flat Ernie
    Flat Ernie
    Tech Editor
    Do some careful measuring on the spring perches. When I installed a Maverick 8" into my dad's '50 coupe, I noticed there was about 3/16" difference between the spring perches & springs themselves.
    Certainly within the realm of play on rubber-bushed springs, but if you're using anything other than rubber, something to look at.
    Definitely something to keep an eye on (spring bushings) for premature wear...
    BUT - it is as near a bolt-in as you will find.
  4. Scrap Heap
    Scrap Heap
    What year Maverick, and what models for the '57-'59 9"?
  5. 50shoe
    50shoe
    early 70s V8 (5 lug) mavericks. 71-77 I think. Watch it though, a few of those years are tough to find brake parts for, the early ones used the same parts as early mustangs. which also are about the right size.
    V8 passenger cars had small bearing 9 inch rears in 57-59. Wagons and Rancheros had large bearing rears. Both were 57 inches wide, narrowest 9 inch ford ever produced.
    good reference:
    http://www.50chevy.freeservers.com/Suspension_Widths.html#REAR
  6. 50shoe
    50shoe
  7. I keep all my reference sites bookmarked, it saves me a lot of time and headaches.
  8. 50shoe
    50shoe
    yeah I had it booked too, too many folders, too many bookmarks.
  9. AWSOME 50
    AWSOME 50
    from buffalo ny
    thankyou for all of your replys it is a great help i love all of the knowledge on this site, someday i hope to answer others with the same john
