50 ford steering box help
Discussion in 'Off Topic Hot Rods & Customs' started by poco, May 23, 2024.
  1. poco
    poco
    from oklahoma
    I am looking for some one that installed a unisteer system on a coil spring a arm steering system, also who sells them. Don
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    I moved this to the off topic forum. Rack and pinion is off topic on the main board
  3. foolthrottle
    foolthrottle
    The only thing I know about the 50 Ford steering box is the bolts are pron to rust out as I found out on a mountain road a few years ago. If you have a 50 Ford with original steering box, check and change the mounting bolts
  4. miker98038
    miker98038
    Look real close when you find one and before you buy it. It’s sometimes pretty easy to stuff a rack in an early car. It’s a whole different thing to not end up with a lot of bump steer, turning radius problems, and steering column modifications.
    pprather likes this.
  5. guthriesmith
    guthriesmith
    On the shoebox we had, seems like there was a Volvo steering gear and conversion kit that worked with the other original steering parts? That kept it more like original but with a better steering gearbox from what I think I remember.
    Chavezk21 likes this.
  6. mustangsix
    mustangsix
  7. pprather
    pprather
  8. pprather
    pprather
