Customs 50 Merc build
Discussion in 'The Hokey Ass Message Board' started by STOFER, Apr 4, 2009.
  1. STOFER
    STOFER
    Thought Id post some pics of a car Ive been working on for a bout a year and a half now on nights and weekends. Its a 1950 2dr Merc I bought from a friend of mine in Mississippi. Pretty rough to start with but price was right and hell its a learning experience. Heres what it looked like when I got it.
    Had the original flathead and 3 spd with overdrive in it yet
  2. Chris Cissel
    Chris Cissel
    from Fresno Ca
    Any current photos to see the progress.
  3. STOFER
    STOFER
    Once I power washed the frame there was more rust than metal so I decided to make my own using 2x4 tubing and mate it to the original front stub.
    custom built frame table
  4. STOFER
    STOFER
    Im putting air suspension on it so I made the rear kickup over the axle blend in with the flow or the frame. Heres the Merc clip welded on. Everything lined up really well.
    Im using a 500 Cadillac motor so I decided to run a rack and pinion setup which required a $hitload of modifying to the front clip.
  5. STOFER
    STOFER
    rear kick up
    rear 4-link from suicidedoors.com I made all the mounts on frame and rear end
  6. STOFER
    STOFER
    Once I got this done I started on the floor, or lack of floor. I had to replace the inner rockers and body mounts too. Basically the entire floor pan and firewall.
  7. STOFER
    STOFER
    homemade body mounts
  8. STOFER
    STOFER
    I used a 500 Cadillac motor and a 400 auto transmission. I got this all set in place before doing the floor.
    Motor mounts I made
    trans mount
  9. STOFER
    STOFER
    rear seat area
  10. STOFER
    STOFER
  11. STOFER
    STOFER
    Im using the stock steering column and Im gonna try and make the stock shifter work with the auto transmission using a cable or some kind of linkage. Not sure yet.
    Heres the steering column mount and also the brake pedal ***embly I fabbed up.
  12. HOT ROD DAVE
    HOT ROD DAVE
    Good job so far,
    hay you want to do a frame for a 52 ford for me????.........ha ha ha
  13. STOFER
    STOFER
    Front frame horns made different so the radiator will clear the hood. I got 2 16" electric fans from my work that fit perfectly.
  14. STOFER
    STOFER
    Thats where Im at so far. Ive been slacking for the last month trying to get my bike all finished up and re wired. I still have a long ways to go but its alot closer from when I started.
  15. Rich Rogers
    Rich Rogers
    500 Caddy huh? That is gonna be killer man. I can already smell the tire smoke. Nice work so far so keep postin it
  16. poweredbylincoln
    poweredbylincoln
  17. poweredbylincoln
    poweredbylincoln
  18. wow! your doin a killer job man , keep us posted on the updates!
  19. woody2
    woody2
    Sweet as, Nice work there for sure.
    Thats going to be one Killer Kustom. Keep the pics comming.:cool:
  20. Midwest Rodder
    Midwest Rodder
    Great job so far, the stance is badd! That 500 caddy should make that thing a bullet.
  21. Movinman
    Movinman
    Wow! The fabrication detail is amazing! Great job brother!
  22. slddnmatt
    slddnmatt
    thats great!! i know how much work mercs take in that condition to build. its looking *****n !!
    matt
  23. 56gasser
    56gasser
    from lower al.
    The fabrication looks great!!
  24. Trashed & Hammered
    Trashed & Hammered
    from HR,Oregon
    Stofer Your work is great....Thank you for joining the HAMB and sharing your progress.
    I'll be following this build for sure.
    ___Trout
  25. Squablow
    Squablow
    Excellent workmanship on this. I can't imagine having to build that frame from scratch.
  26. Bad Bob
    Bad Bob
    from O.C. Baby
    That is really really nice metal work!!! You are doing a fantastic job! Hope to follow your progress...
  27. 38FLATTIE
    38FLATTIE
    from Colorado
  28. poorboy
    poorboy
  29. Very cool thread.
    I have a '49 Linc coupe that I have just dropped a 500 caddy engine into.
    My ch***is has been fully boxed with new crossmembers and a Jag front subframe graft and jag diff.
    Love them caddy 500's.
  30. punkabilly1306
    punkabilly1306
    from ohio
    great build, i have a caddy 425 planned for my '51...any more shots of your rocker build?
