50 Olds coupe with oil pressure problems
Discussion in 'The Hokey Ass Message Board' started by Oldsmobile Art, Aug 8, 2013.
  1. Oldsmobile Art
    Oldsmobile Art
    I have a 50 Olds coupe with a 400 cubic in.67 Olds engine. When it is cold and first stars up, oil pressure is 65. Has Stewart Warner mechanical gauge. By the time it warms up to about 200 degrees, it will drop to as low as about 5 lbs. The engine has been completely rebuilt, all new stuff in the bottom end, roller lifter cam. Using stock radiator and aftermarket trans cooler. Has a turbo 400. Have driven it about 40 miles. I put in 15-40 weight oil after this first happened and it didn't help. Can anyone help me with this problem?
  2. leaded
    leaded
    from Norway
    Have you checked the oil-pressure relief valve? Got similar trouble, and it was the valve..oil bleeding past it all time.
  3. sololobo
    sololobo
    It is a goner, best sell it to me and rid yourself of the problem. In reality I am just jealous as I miss my 49 Olds coupe I sold years ago. Hope you get the problem solved. ~sololobo~
  4. hotrod40coupe
    hotrod40coupe
  5. Gman0046
    Gman0046
    The first thing I would do is hook up a direct reading gauge to verify your indication system. Could be as simple as a bad oil pressure transmitter or gauge.
  6. hotrod40coupe
    hotrod40coupe
  7. vtwhead
    vtwhead
    call Tony at Ross Racing. If anyone knows what to do he would be the guy.
  8. greybeard360
    greybeard360
    Is that 5 psi at an idle or revved up a little..... need a little more info to go on here.
  9. Ole don
    Ole don
    Go back and re-read number two.
