Search function isn't playing well with searching........ So- Seen a bunch of pic's, but have some Q's for those who have/done..... 1- if centered in the middle of the panel below the deck lid, how did the arc of the panel affect the mounting of the light=IE- the light is flat, and the panel curves more at it's center. 2- if centered = what kind of gap should I expect, and would more of a gasket be sufficient?=thicker? I can make a template, and measure, but want real world experience. 3- did you mount lower on the panel to avoid "more" of the arc? I'm going to run these because I like them. I just am looking for any pitfalls, should'as, would'as, could'as..... Can run lower at bottom of panel, or centered. Thinking mid-way, but would like to hear the pro's and con's.... A lot of my lil books are black and white, and I can't ask the owners/builders...... Seeking real world knowledge here......Thanks-Kid
I think anywhere on the lower panel works with no gap or issue's been done a lot Good luck drill away
Hi Put tear drop taillights in my model a, with rumble lid with no problem with the curve in the back panel. Dave
