50's Mopars Lug Patterns
Discussion in 'The Hokey Ass Message Board' started by Slick Steve, Feb 27, 2008.
  1. Slick Steve
    Slick Steve
    from Indy
    Hi All...
    Does any one know what the lug pattern is for a 51 Dodge? Is it 5x5.5? Is it the same as fords of the same time? Thanks!
  2. chrriff
    chrriff
    I used to have a 50 Chrysler Windsor. It had the standard 5 on 4.5 lug pattern. The only thing was,it had an alignment pin which could be knocked off with a hammer. If your running unilug wheels with a Ghevrolet/Mopar(Ford) Bolt pattern the alingnment pin doesnt need to be removed. Rememebr that even on those old Mopars,that the drivers side lugs are left hand thread and the p***enger side is right hand thread.
  3. RodStRace
    RodStRace
  4. OLD HEMI
    OLD HEMI
    The early mopar lug pattern is the same as Ford , AMC,early IH 1/2 ton pu's. The Mopar center hole is slightly bigger than the Ford & AMC. I put 15" Ford wheels on my 55 PU, they worked fine after grinding out the center hole approxemently 1/8 of an inch. Hope this helps.
    OLD HEMI
