51-53 chevy question
Discussion in 'The Hokey Ass Message Board' started by johnnyjalopy, May 20, 2011.
  1. johnnyjalopy
    johnnyjalopy
    hey will a stock 53 chevy car standard trans, master cylinder working a 51 with powerglide? if not what do i need to do to make it work? got one for free.
    thanks... johnny
  2. 54metalman
    54metalman
    They should work just fine. Might be a slight diff in the mounting holes but doubt it. Had way too many of those to count.
  3. johnnyjalopy
    johnnyjalopy
    my 51 only has one hole and the standard i got has two for the pedal...johnny
  4. 56sedandelivery
    56sedandelivery
    You'll already have the clutch pivot for the master cylinder if you ever decide to convert to a standard trans. We cut the clutch cross shaft off and left it in the master cylinder when we went the V-8/auto route; that way the "lock pin" won't get corroded in place. This was on my nephews, formerly mine, 51 Chevrolet Business Coupe. Other than that, they're essentially the same. Butch/56sedandelivery
  5. johnnyjalopy
    johnnyjalopy
    sweet! so just dont use the the top hole? hook everything else up the same?..johnny
  6. 302GMC
    302GMC
    from Idaho
    The '53-'54 master is 7/8" bore, earlier is 1'' ... you'll think you added power brakes !
  7. johnnyjalopy
    johnnyjalopy
    but it will work right?...i am going to have my family in the car just want to make sure it will work right...thanks johnny
