Projects 51 buick special "the Shane Asylum"
Discussion in 'Traditional Customs' started by hacknwhack, Mar 11, 2014.
  1. Olson
    Olson
    Lookin' good.
  2. aw1950
    aw1950
    Impressive looking Shane . I am jealous !!
  3. jocktherock
    jocktherock
    from Sweden
    Like a wet lolypop... I'm also jealouse! Sorry for my bad americana
    hacknwhack likes this.
  4. hacknwhack
    hacknwhack
    from mass
    Dont be. you will get there too. Take your time. Andy
  5. hacknwhack
    hacknwhack
    from mass
    Got the front back together.
    Polished things
    the best i can. Still need to save some cash for the chromer. Gonna leave it this way for the winter.
    Lookin for a pair of 55 56 buick dagmars to cover the bumper bolts.
    Also im clueless to front turn signals ...ideas?
    Something hidden behind or between the grill teeth?
    Tried to fix the upper grill
    With alumaweld. Had mixed success. worked well on my vent windows in the past. But on the thin bar ... fail .
    i think the melt temp is too close
    Now got a bigger mess
    Not showing pics.:mad:
    Looking to buy some muggy weld for pot metal. The say it melts at 350 degrees vs the potmetal at 750.
    Different than the old muggy for alluminum
    Anyone tried this?
  6. LONG
    LONG
    man, I really like how you did the grill bars all the way across. and the custom upper lip.
  7. hacknwhack
    hacknwhack
    from mass
    I posted the french lip earlier in this thread.
    Had to french it because the 53 isn't a bolt in to a 51
    As for the extra teeth;
    I used two 53 grills
    cut 3 bars out of each side of donor grill
    Cut and Welded in where turn signs were.
    Had to add brackets to mount onto bumper.
    Also dropped the bumper 2 inches using modified
    Brckets and a drop plate at the frame.
    Pics tonight.
    Somewhat simple cut and paste.
  8. Chrisbcritter
    Chrisbcritter
    That's a toughie; it's such a clean design and you don't have much space between the bars. Maybe swap out the last vertical bar on each side for something that harmonizes with the rest of the grille? I tried a set of '60 Pontiac backup lenses turned vertical with the pointy end on top:
    Or use the last teeth as molds for plexigl*** lenses? The other idea was a set of '60-'63 Mercury Comet wraparound turn signals in the lower corners of the front bumper.
  9. hacknwhack
    hacknwhack
    from mass
    Thanks Didn't think of that.
  10. Angry Frenchman
    Angry Frenchman
    looking awesome Shane!!
  11. BORRACHO13
    BORRACHO13
    from Menifee CA
    sweet grill bro, great job!
  12. hacknwhack
    hacknwhack
    from mass
    Thanks guys.
    I appreciate you comments.
  13. hacknwhack
    hacknwhack
    from mass
    Cutting another Windsheild today.
    Ran over the first one i cut a a few years back.
    Had a crack in it any way.
    From improperly dressing the edge.
    I didnt have a belt sander at the time and tried using a
    90 degree die grinder with rolock disk. Failed
    Nuff said.
    2nd time was a success
    Heres how i did it...
    Match marked the gl*** on both sides
    I liked the old fit
  14. hacknwhack
    hacknwhack
    from mass
    Got a new 4.5 inch gl*** tile bit. Popped it in my grinder.
    Rigged a hose to the guard
    By drilling a small hole.
    Then inserted using my wet sander hose valve.
    Put the other end in a 5gal bucket. Hung that from the ceiling. Filled with water.
    ...gravity feed.
  15. hacknwhack
    hacknwhack
    from mass
    Got the obligatory safety gear out.
  16. hacknwhack
    hacknwhack
    from mass
    Disclaimer.
    Water and electricity don't mix. You could be graveyard dead
    Eric H likes this.
  17. hacknwhack
    hacknwhack
    from mass
    Duct Taped both sides.
    As a guide line.
    There's no way i can follow the pen line with the water and debris flying.
    Seemed to help keeping the water in the cut line too.
    Starting from the back side
    I Opened the water valve
    Took a deep breath. .
    Starting at one end made a light quick steady p*** only scoring the gl*** maybe 20 or 30 seconds end to end.
    No pressure lust letting the tool pull and i just steered
    Repeated this seveal times till i was half way to the plastic.
    Flipped the gl*** and repeated, stopped halfway to the plastic.
    Flip again cut the back to the plastic.
    Flip again cut TO and then THROUGH the plastic.
    I RECOMMEND. .IMHO Not cutting as if you were cutting plywood.
    Take your time
    Eric H likes this.
  18. hacknwhack
    hacknwhack
    from mass
    Success.
    But its just the beginning. .
    Eric H likes this.
  19. hacknwhack
    hacknwhack
    from mass
    Placed a few sections of
    Old window rubber on the lower opening, for a "check fit"
    Eric H likes this.
  20. hacknwhack
    hacknwhack
    from mass
    1. Its obvious the upper corners need to be radiused.
    2. The sides need to be trimmed in a wedge.
    3. And 9 inches of each lower bottom outer edge need a quarter inch removed.
    Reason for the outer and
    bottom?... roof swap.
    Upper header is a hair narrower from cutting at junkyard
    And the A pillars got laid back 1/4 inch in the build.
  21. hacknwhack
    hacknwhack
    from mass
    Marked and taped
    my cut lines .
    Made several straight cuts.
    One at a time. Its hard to cut a curve in one p***.
    Eric H likes this.
  22. hacknwhack
    hacknwhack
    from mass
    Another check fit.
    Getting there
  23. hacknwhack
    hacknwhack
    from mass
    Got my El cheapo belt sander out. The belt cost more than the used tool!
    What i got will do for now.
    Sanded the edges and smoothed the radius' .
    Using gravity feed water,
    Sanded inline with the edge.
    Creating a smooth bevel
    Preventing those small chips from becoming long cracks. Don't go across you will only make more chips.
  24. hacknwhack
    hacknwhack
    from mass
    Cleaned up the edges.
    Put my 4x readers on to check for chips and cracks.
    Found this.. just starting
    About 3/64 INCH
  25. hacknwhack
    hacknwhack
    from mass
    Took another deep breath.
    Out comes the tile wheel
    Again.
    Cut a small curve to the crack. Then smoothed out with the sander.
  26. aw1950
    aw1950
    Shane is that a special cutting wheel or can you pick one up at your local Home Depot ? I am ***uming its a diamond coated cut off wheel . Also where can a guy get a heaping load of nerve to do this? LOL! How much time is involved ? Later , Andy..
  27. hacknwhack
    hacknwhack
    from mass
    Saved
  28. hacknwhack
    hacknwhack
    from mass
    Now if i can only find all that trim.
  29. hacknwhack
    hacknwhack
    from mass
    Gratuitous bootyshot
  30. hacknwhack
    hacknwhack
    from mass
    kiwijeff likes this.
