51 Caddy Rear
Discussion in 'The Hokey Ass Message Board' started by CADILLAC AL, Apr 2, 2007.
  1. CADILLAC AL
    CADILLAC AL
    Does anyone know of a ' later model' easy/direct swap for a 51 Caddy 62 series 4dr sdn rear?
    Thanks in advance,
    Al:cool:
  2. Dale Fairfax
    Dale Fairfax
    Any particular reason why you want to replace it? As I remember, it's Hell for stout and probaly already has a decent gear in it.
  3. CADILLAC AL
    CADILLAC AL
    Dale,
    Mainly because of age & wear. Also wouldn't mind a little better highway gear.
    Thanks,
    Al:cool:
  4. Caddy-O
    Caddy-O
    If I remember correctly the dimensions are pretty close. You may have to relocate some of the mounting surfaces to get it fitted, so I wouldn't call it a direct swap. You will also have to use the later model drive shaft because the two are different, the early shaft will not work with the later rear end.
    Hope this helps.
  5. Hubnut
    Hubnut
    Buddy of mine put a late model Chevy truck rearend under his 52. It was a bolt in. He didnt change a thing, and it kept the 5 on 5 bolt pattern. If you need me to I'll find out exactly what rear he used.
  6. HoldFast
    HoldFast
    wonder if there's a gearing difference from your car to my 53 because my car LOVES the highway. Cruises at 70-80mph. Hit 115 on the stock motor pretty easily as well.
    Good luck with the find. It'll be good info for me to stick in my brain if anything ever happens to mine.
  7. CADILLAC AL
    CADILLAC AL
    CADDY-O ???
    HUBNUT, If you could, I will be very grateful.
    HOLDFAST, Sounds liks a fun ride (pics, please). I run a modified 500 & am trying to get a little more than 8mpg.
    Thanks Gents, Al
