51 Chevy car rear end swap
Discussion in 'The Hokey Ass Message Board' started by sinner13, Sep 12, 2006.
  1. sinner13
    sinner13
    from Buffalo NY
    Hey guys,
    What would be a good rear end to swap in to my 51 chev?
    I heard 71 to 81 camaros are a good donor....any thing else a direct fit as far as length goes?
    Thanks
    Will
  2. Will,
    S-10/Blazer 4X4 will fit. It is 60" hub to hub and probably alot easier to find than a 2nd generation Camaro.
    Todd
  3. sinner13
    sinner13
    from Buffalo NY
    Thanks Todd.....any particular year?
  4. Hellfish
    Hellfish
    53-54 Chevy rear end is a direct swap with better gearing... but you probably want an open driveline
  5. sinner13
    sinner13
    from Buffalo NY
    Ya, that's the only reason Im doing it, no probelms with what it has, but I'm thinking future mods would be easier with a open drive line....
  6. 60" is about ideal...I'm running a '78 Camaro rear and the tires barely fit. I'm going to have to cut out the inner lip of my skirts a little 'cause they rub on the tires.
    Check this link for common rear-end widths http://carnut.com/specs/frear.html
    Bryan
  7. OLLIN
    OLLIN
    powerglide rearends right? they have 3:55's. I wouldn't mind making that swap too. wont be able to peel out anymore though...
  8. sledbuilder
    sledbuilder
    I got a buddy who has a 55-57 Chevy rear in his.... seems to work well.
    Jason
  9. Royalshifter
    Royalshifter
    Moderator
    I installed a 77 camaro in the 55. perfect.
  10. 49ratfink
    49ratfink
    had one with a 74 camaro rear and couldn't run my skirts with my aftermarket chrome wheels... may have worked with the 5" stockers.
    my new 49 has a 65 nova 10 bolt rear. it is a bit narrower at 58" rim to rim. 65 - 67 nova. 67 - 69 camaro are all the same I think... not sure if the 63 64 nova rears had 5 nuts or not... but it would be another to consider, though they are the early 55-57 style rear.
  11. 49ratfink
    49ratfink
    hmmm looking at the chart from above it appears 67 69 camaro rears are 60". I like my 58" nova rear since I'm running 14 x 7 american 5 spokes
  12. Lots of choices fit, 55-57 Chevy, 55-57 Pontiac or Olds (different bolt pattern), 67-81 Camaro, 74-79 Nova/Ventura/Apollo/Omega, and 82-up S10 4x4. A lot of these need the holes for the locating pin moved if you use the stock springs.
    The stock springs are designed for a closed drive, so you'll get wheel hop without some kind of traction bars. Posies makes replacement springs and someone else makes a kit that changes the spring perches and everything -
    Heck, if you poke around you can probably find a 53-4 PG car rear for free. Those and the 5-6-7 Chev rear all use the same brakes, so you could swap your existing parts over if they're good enough.
    I have a '55 rear I'd let go of for like $100 - and that only because it's still in the car, a 265 PG car - about 3 hours down the Thruway from you -
  13. sinner13
    sinner13
    from Buffalo NY
    Thanks for the info guys, and rustynewyorker, if my line on a s10 rear doesn't work out..Ill pm ya about the 55 rear....
  14. Hellfish
    Hellfish
    Yeah, and 53-54 manual trans cars had 3.70 gears, so they were also good and better than the 4.11s of the 49-52 cars
  15. if you are running stock rims (15x6), the camero works perfect!
  16. J A G
    J A G
    from Ohio
    Hello, new here & worken on a 52 deluxe (with closed drive) I don't like the high rpms. either so let me know what u decide is the best. Mabey I'll try it also . Running a 235 fresh rebuilt & still thinking of trans ??
  17. The Nova rearend fits perfect. I have one in mine and it fits perfect with stock rims, and I could go a little wider.
  18. JRODHOTROD
    JRODHOTROD
    from Manor, TX
    mine is out of a 62 vette or a 57 chevy(same rearend) works real good
  19. tinmann
    tinmann
  20. old dirt tracker
    old dirt tracker
    from phoenix
    S10 rear,s come in several width,s and a lot of them come out of vehicles with overdrive you could end up with a really low gear.
  21. I also have a 52 DeLuxe, but I scored a complete powerglide rear end for mine, I think you can get a ring & pinion set from Patricks that will give you a better rear ratio as well. The 53-54 rear ends & PG rear should go right in, if you want to keep a closed drive. I'm trying to keep mine as trad as possible so I'm sticking to the torque tube.
  22. Jason455
    Jason455
    I just installed a 79 camaro rear in my 54. I bought it at my local U-pull for $36. I measured the widths before I installed it. The camaro was 1/2" wider than the stock rear. I keep hearing they are 2.5" wider? The 54 was 60.75" wide with drums. the camaro was 61.25" with drums. The springs line right up. Definately the easiest rear end to use. Check your local craigslist or car-part.com There are still lots of these rears for sale. S-10 have the 7.5 ring and pinion. Not good for lots of power. Camaro is 8.5.
  23. Will,
    You live in the rust belt like I do. It may be tough to find a 2nd gen. Camaro. I called all my local scrap yards and they laughed at me. The S-10/Blazer 4X4 was a easy find. Do a google or Yahoo search for "Chevy Rear end codes" The one I wanted was 3.43 reaer which was code GU6. You can find the codes on a sticker in the glove box.
    Todd
  24. crazycory1
    crazycory1
    I see that you posted this on 09-12-2006, did you find a rear yet?
    I have a chevy 10 bolt rear, I believe its out of a nova but not sure. It measures 60" flange to flange and has a 5x4.75 bolt pattern. $150 and its yours. I live in belvidere, nj 07823
    Email me at crazycory@lycos.com if your interested.
  25. sinner13
    sinner13
    from Buffalo NY
    Crazycory,
    I haven't found one yet, although I haven't looked to hard, a zillion other things going on...
    I would be interested in what ya got, just don't want to pick it up...interested in shipping it?
  26. crazycory1
    crazycory1
    Sorry I just realized you replyed to my post.
    Sorry I sold that rear.
    Hope you found one and are working one your project.
  27. bigsam63
    bigsam63
    I used a 74 camaro in my 51 worked fine.
  28. Saoutlaws_Gotti
    Saoutlaws_Gotti
    hey sinner did you find on yet
    just curious to see what you used and how it worked
    i just put a 59 235 in my 53 and i hate it so im going to driveit into the ground and in the meantime look for parts to do a sbc conversion
    i read somewhere (thinkin it was 50chevy.com) that a 57 chevy rear will bolt right in on the old springs with no mods (i just so happen to know where there is a 57 chevy wagon i can get it outta) is this true guys ?
  29. sinner13
    sinner13
    from Buffalo NY
    Hey Saoutlaws Gotti, I had my buddy build me one using a ford 9"..
    Ill be four linking so I figured I might as well go new...
    Plus he owed me favors...so Im not gonna complain ;)
    As far as the 57 goes, not sure if the wagon is the same...
  30. I have a '74 nova 10 bolt, works great, great clearance. Something like 58 or 59". I bought the Chassis Eng. rear springs kit for about 400 and it was great. Stiff ride though.
    For stock springs, PM Fat Hack, he did a great post on how exactly to do this swap with the stock springs, including measurements. I searched for it but couldn't find it.
    A '57 rear would be great, it's practically a bolt-in. Is '55 the same?
    brad dalton likes this.
