51' Dodge Disc Brake Conversion help
Discussion in 'The Hokey Ass Message Board' started by Slick Steve, Mar 8, 2009.
  1. Slick Steve
    Slick Steve
    from Indy
    I bought a disc brake conversion kit from ECI for my 51' Wayfarer. I started to install it today and it went on great. Problem I want to run the stock wheels and hubcaps and they are rubbing the calipers. What are my options? My 1st thought was to get a 1/2 inch spacer and longer lugs. Would that work? Is there another type of stock type steel wheel I could get that would work? Thanks!!!
  2. hotrod-Linkin
    hotrod-Linkin
    it says on the website..stock wheels will not work.get some ford wheels that are for disc brakes.
  3. I have disc brake conversions on my Plymouths ('39 & '46). Both have stock suspensions and I went with Wheel Vintiques smoothies.
  4. bob-n
    bob-n
    I've got steelies off a 1/2 ton dodge van on my 52 Wayfarer. Also run ECI brakes.
  5. 1/2" spacers will do the trick if you want to keep your stock wheels. They're dirt cheap at any parts place.
  6. bct
    bct
    dakota rims worked for my ECI conversion , barely
  7. ECIGUY
    ECIGUY
    Don' use spacers, and DON'T ATEMPT TO CHANGE THE STUDS-GET SOME OTHER WHEELS.
  8. BenD
    BenD
    Alliance Member
    Could you switch to the earlier 16" mopar wheels and gain clearance? Same hubcap.
  9. Slick Steve
    Slick Steve
    from Indy
    That is the plan. I ordered new ones from "Wheel Kid" on here from rally America. I should have them next week!
  10. StanDaManTX
    StanDaManTX
    from The South
    did you get the 14's or 15's? i am about to order some wheel vintiques 14" smoothies and i'm hoping they'll fit over my eci brakes.
  11. blueskies
    blueskies
    from Idaho
    Are your original wheels 14" or 15"?
    Pete
  12. Ranunculous
    Ranunculous
    My 14" chrome reverse wouldn't clear the calipers....Now I've got 15" spacesaver rims (for now).
  13. bct
    bct
    my stock 15" wouldn't work but i'd also like to know if 16s would work....i'm thinking no ,as the stock wheels had a bevel in the critical area and the new style have a notch....
  14. Why not? Why are you yelling? I'm running 2.5" spacers. Extreme I know. They're hubcentric, I've never had a problem. IMHO they are ok to use if needed.
  15. Slick Steve
    Slick Steve
    from Indy
    15 inch. I was told I need 13 1/4 to clear. 14 sounded a little to close to me, so I stuck with the original 15's.
