51 f2 brake pedal
Discussion in 'The Hokey Ass Message Board' started by north side, Mar 4, 2013.
  1. north side
    north side
    from texas
    hey does anyone make a single brake setup( no clutch pedal) for my f2? or is the easiest way would be to cut the clutch off below the floor? just wonderering.
  2. RMR&C
    RMR&C
    from NW Montana
    You should be able to remove the pedal from the cross shaft and put a spacer in it's place. Or cut the pedal off right above the shaft.
  3. north side
    north side
    from texas
    That's what I was thinking . Thx
  4. FrozenMerc
    FrozenMerc
    That is all you have to do. I am running firewall mounted brakes, and the original through-the-floor clutch on my '51 F1. Works great with just a spacer.
