51 Ford F1 pickup questions
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by martinkoe, Oct 18, 2008.
  1. martinkoe
    martinkoe
    from Central VA
    I am starting on a 1951 F1 Ford pick up project and am looking for pros and cons on turning this into a reliable driver. I currently have a 1997 ford 4 dr Explorer as a donar vehicle. I saw a post here about folks using S10 frames and 1 post about using a Ranger/Explorer frame. Has anyone done this, if so what major and minor snag points will I run into. Also, the 5.0 engine in the explorer uses a distributorless ignition. Has anyone found any aftermarket wiring harnesses that are designed to work with this setup.?
  2. sonnythebull
    sonnythebull
    or alternatively www.oddballkustoms.com culd make you a whole new frame for a really reasonable price
  3. Doraville
    Doraville
    from Georgia
    I have a '52 F1 that has a front clip from a '78 Monte Carlo (Cutl***, Regal). I didn't do the conversion; it had already been done when I bought the truck. The truck drives pretty good however.
    My only complaint is that it lowered the truck about 3 inches (I prefer stock ride height). I am currently researching ways to raise it back to closer to the stock ride height.
    Peace,
    -DV
  4. most folks that swap in an S-10 frame don't use the engine from it so the wiring harness gets tossed.. remember "Traditional" hot rods and customs are the name of the game here so i wouldn't go asking around much about a fuel injected 5.0.. i hope that explorer was 2 wheel drive also..
    hope that didn't sound rude.. wasn't trying to.. just giving you a heads up..
  5. dvs28
    dvs28
    from pacific nw
    I drive my 50 F-1 daily, 1953 chrysler 331 and a top loader. I guess it what you want to drive?
  6. PegLegStrick
    PegLegStrick
    Welcome from South Georgia
  7. henrys_way
    henrys_way
    from Maine
    You can make her a good reliable driver with the stock frame too... nothing wrong with doing that. Thats how mine is. original running gear, just has a 12 volt system now.
  8. Ford-Man
    Ford-Man
    Depending on who you talk to, the stock frame is a better frame anyway! I would say dropping a 5.0 is a good idea, but I would not drag the electronics with it unless you are comfortable wiring everything back up. A stock 302, 289, 351 with a 2bbl or 4bbl is a solid bet for the long haul if you want to stick with Ford, and they are fairly easy to maintain with parts being available pretty much anywhere...same as your modern 5.0. If you still want overdrive, then get an AOD trans. No electronics needed. If your frame is pretty well shot, you are in luck because F-1 frames are pretty easy to find.
