Technical 51 ford Industrial flathead
Discussion in 'Traditional Hot Rods' started by hotrodderhaag, Sep 19, 2013.
  1. hotrodderhaag
    hotrodderhaag
    I came across an industrial flathead from 1951. Looks in excellent shape. Runs great. Has been taken care of from appearance .... What all is different on these?? I planned on adapting it to my 34 ford trans .. What all is needed to do that ?
    Thanks guys ..... I already did the search. A few decent ones came up but nothing real informative .
  2. carmuts
    carmuts
    You will need the F-1 3 spd adaptor and clutch inspection pan. You should be able to pick them up for about $100. There was a thread showing the differences in the adaptors, but I do not have time to do a search for it right now. Rod
  3. walter
    walter
    To the best of my knowledge there are no internal differences. I would suggest make an appearance on the Ford Barn. Those guys real speak Flat Motor.
  4. carmuts
    carmuts
  5. hotrodderhaag
    hotrodderhaag
    Are the heads the same stud pattern ?
  6. Bruce Lancaster
    Bruce Lancaster
    It should be basically a truck engine of same year. Any differences will be external stuff like governors, clutch, etc.
  7. rotorwrench
    rotorwrench
    If it was an engine made in 1951 it will be in the 8BA family that has no bell on the back. If it was manufactured outside of FoMoCo it may have an older 59 series engine. It just depends on whether it is a genuine Ford unit or some other manufacturer. If it's an 8BA series, It would be interesting to know if it has the truck rear sump pan with the clean out or something else.
