51 ford PU VIN Plate?
Discussion in 'The Hokey Ass Message Board' started by shoebox72, Sep 2, 2003.
  1. shoebox72
    shoebox72
    I'm going to look at a 51 ford PU and the guy wasent sure where the vin numbers are. The truck has a volare clip, if the numbers are on the frame could putting the clip on make them un readable? Are there numbers on the inside of the glovebox? I just want to make sure everything is kosher because CT is a ***** about vin numbers/vin plates.
    thanks, Billy
  2. Bigcheese327
    Bigcheese327
    Did they do VIN's in the early fifties? Seems to me they weren't required until the late-fifties/early-sixties and that vehicles were registered maybe by engine numbers in the early days. Without the flathead, you could be SOL.
  3. Edselow
    Edselow
    from TN
    I don't know specifically about a '51 Ford PU, but usually the VIN (called serial numbers back then) on most cars was either on the firewall on the driver's side or on the driver's side door jamb (hinge end).
    Alan
  4. topdeadcenter
    topdeadcenter
    '51 ford PU VIN data plates are on the firewall on the p***enger side. (I used to have one)
    TDC
  5. old beet
    old beet
    Top of the p*** side frame rail, starts with a star then F1 numbers ends with a star. May be a plate inside glove box, but usually missing. Look for the screw holes...OLDBEET
  6. shoebox72
    shoebox72
    THANKS GUYS. [​IMG]
    Billy
  7. carkiller
    carkiller
    VIN tag on glove box door as well as left frame horn in front of steer box. Cal
  8. BELLM
    BELLM
    P*** side firewall and inside glove box lid & top of frame, I think lft side. If you need decoding info e-mail it to me @ Eddie_Bell @ msn.com.
  9. The vin is also stmed in the firewall just below the seam on the drivers side
  10. ST62
    ST62
    Glove box on mine.
  11. 52lomofo
    52lomofo
    52 likely the same?
  12. alchemy
    alchemy
    Gee, I wonder if he bought that truck, 15 YEARS AGO?!
  13. gimpyshotrods
    gimpyshotrods
    Can't be!
  14. Mr48chev
    Them 52 Ford truck guys sure must lead boring lives to dig up 15 year dead threads.
