51 ford shoebox floor pan questions?
Discussion in 'The Hokey Ass Message Board' started by True till Death, Oct 12, 2010.
  1. True till Death
    True till Death
    So I am having custom dies made for a bead roller to make my floor pans. This is my first time making my own pans and working with metal fab in general.
    My question is will there be any stretch when I roll the beads? I.e. if I cut the bad pans out and say measure 1 foot and I make the pans will it stretch to 1 foot X inches? Or will it shrink?
    I want to make sure I understand how the metal will be affected so I’m not using tons of material.
  2. Da Tinman
    Da Tinman
    cut the patches slightly oversized if your worried about it.
    I really havent noticed much shrinking when applying beads, just dont over do it.
  3. KrisKustomPaint
    KrisKustomPaint
    it will shrink in the bead area. Most people that have access to an english wheel will pre-stretch the area in the bead to account for this. You will probably find that you will produce an oil can condition trying to build floor pans. you could use a plannishing hammer to pre-stretch if you have one.
  4. happy hoppy
    happy hoppy
    KrisKustom is right, I rolled some beads in some flat stock to make a floor patch for my shoebox and it shrank a little. I cut it a little bigger then I needed so it was not a problem.
    didn't think about rolling it 1st, thanks for the tip.
  5. Finnrodder
    Finnrodder
    from Finland
    It'll shrink a bit,but i've noticed that there is also some warping.I've hammered the the pieces straight.I guess i'll try planishing hammer at next time.I hope those dies work with your project...
