Hot Rods '51 FORD SHOEBOX
Discussion in 'The Hokey Ass Message Board' started by Shoeboxdriver, Nov 7, 2021.
  1. Shoeboxdriver
    Shoeboxdriver
    from Holmen, WI
    So about 10 years ago I sold a '51 ford Tudor with a built tasty flathead with 3 speed O/D, and I missed it ever since. Just bought a scary similar 51 (same color) which is also a 6 cyl. car as was the first. I am building another ,what should be really nice flatmotor for it. For the first car, I found a 3 speed with overdrive trans. which worked GREAT. I am now sourcing all the bits, as well as the trans itself, to do again, but I am wondering if going with a common 5 spd might be better? WELCOME ALL COMMENTS!
  2. 210superair
    210superair
    from Michigan
    I've got the auto 4 speed in mine, and often wish it was the 5 speed. I don't mind a 3ott, but I probably wouldn't put one in if I was building. Just my 2 cents tho. Opinions are like.... Well, you know.
  3. F-ONE
    F-ONE
    from Alabama
    Well, several thoughts...
    The flat 6 was a really good engine. Many say it was a better engine than the V8 with surprising performance.
    The stock 3.73 rear and standard transmission in my 51 V8 Coupe, gets around really, really well. I see no need for any type of overdrive.
    5 speed?
    You may have issues with the shifter being in the seat depending on what 5 speed. Then there's the clutch. I would not do it.
    I just don't see the big gain with a 5 speed OD.
    The only gain I see at all with any OD is on a car with a 4.11 rear.
    seb fontana likes this.
  4. Shoeboxdriver
    Shoeboxdriver
    from Holmen, WI
    Thanks guys for the responses,
    I remember how I really enjoyed the 3 spd w O/D, and I agree the flat 6 does run out pretty good, but I have SO many desirable parts, I am going to build another flat 8. SO, I will continue my search for a decent O/D trans, they're out there, just too often far away.
