51 glide into a 53
Discussion in 'The Hokey Ass Message Board' started by bdr1, Dec 28, 2010.
  1. bdr1
    bdr1
    Before I am reamed.......yes I searched.
    What flex plate and torque converter are needed to put a 51 powerglide into a 53 Belair? One has the converter held on with a nut, the other has the stub.
    From what it looks like, I just need a flex plate and a converter, but I cannot find an accurate description of the parts needed.
    Thanks!
  2. bdr1
    bdr1
    does anyone know the difference between a 51 AND 53 flex plate?
  3. Harris
    Harris
    Why not just stick with a '53 power glide? Not trying to be an ass, just curious.
  4. bdr1
    bdr1
    the 53 trans is shot and I have a fresh 51 sitting on the floor.
  5. Hnstray
    Hnstray
    from Quincy, IL
    I don't know the answer to your question about the flex plate/torque converter, however, I just want to note that the '51 'glide starts off in "Hi" gear in the D position and if you want "low" you have to manually downshift the lever, then move the lever to "D" when you want the upshift. Starting in '52 glides they start in low and self shift to hi. You may very already be aware of that, but just in case you are not it may save you some consternation when you began driving it.
    Regards,
    Ray
  6. bdr1
    bdr1
    yeah, I knew they had that slight difference. It's one of those deals where is simply doesnt make sense to put a $800 tranny re-build into a $2000 car. :(
  7. bdr1
    bdr1
